Oil blow by?
corleykj
Jack of some, definately master of none.
Casper, WY
Thanks in advance. I am hoping a few people can give me some places to start for solving this issue on my 1978 FJ40 2F with weber carb. I am hoping to fix for $400 and mostly my own labor.
OIL thoughts: My wife says I always smell like smoke (from inside the cab) after driving the fj40. So I am trying to figure out where to start. Do I do a compression check and check valves again? Do I assume the worst of piston rings being worn and letting oil by and try finding a used 2f or getting a full rebuild?
Fuel thoughts: I think my fj40 is running rich due to the weber jets not being the correct size for altitude. I am planning on ordering some jets and rebuilding the carb again. So fuel may be some of what is getting out the tailpipe, but I still think it is oil.
Anyways, just curious if someone sees the picture of what is coming out of my exhaust (and ended up on this fence) and can give me some advice on where to put my time troubleshooting.
Thanks again.
Kyle
What does your exhaust smell like?
You can tell what's coming out of the tailpipe by smell. Fuel smells like, well... fuel. And oil smells like, oil.
What does your exhaust feel like?
Put your hand back there and see what you get. Does it feel oily?
What color is your exhaust if you can see it?
Blue is oil, white is water.
Your splatter on the fence looks like water vapor and carbon by the way it's dripping.
No offense to your wife, but a vehicle doesn't smell like smoke unless it's on fire.
Thanks again.
Kyle
Post a few pics of your current tail pipe set up and how it relates to your tub / body
if Your tailpipe is cut too short or Not at the right angle sticking out far enough , Exhaust gasses can be rolling under your Tub and entering the Cab instead of being swept away properly by the passing rushing air
The webber should be inspected for proper function and make sure its Not simply Dumping fuel out of a 5 gallon bucket down your intake
The "Detroit philosophy " of more gas = more fast Really Does Not work all that well on a HIGH Quality Low RPM Japanese Made Engine ........
Only been in Wyoming just passing through but am thinking it is quite arid there so my first thought of condensation in exhaust may not be the answer to the splatter.
Rich fuel mix could be the problem or rings and or valve guides.
Does your Toy use oil?
My main concern would be fumes in the cab.
I would check for exhaust leaks and holes in the floor and firewall.
When running with the rear door lifted up and windows open exhaust will sometimes suck in through the back but with everything buttoned up there should be no problem.
@4x4veteran is on it ,
Remember the Webber is a SMOG free Carb , Similar to a NON -USA Factory carb and will Produce Significantly More HC. / Co. /
& NOX.
Then a USA spec emissions Carb
look for holes in both your exhaust and floors , as well as be mindful of rear hatch / Ambulance door side vent windows / soft top open Use until U sort out the bad exhaust ODOR
Exhaust gases should not be in the cab. If so, fix your exhaust system.
However, there could be oil leaks on the engine, which may waft into the cab.
Water vapor is a major component of exhaust gas, and unburned carbon as well. Both are evidenced in your wall picture.
Hahaha. She actually didn't say it smells like smoke, that was my interpretation late at night. She said "something is burning where it shouldn't be." I have adjusted valves but can open it up and check again. I can check plugs for fuel smell and I will also have someone start it for me so I can check the exhaust. I rerouted the exhaust out the side (pictures to follow) to help it draft when driving with the top off.
Thanks again.
Kyle
Did you ever find out what was happening and what worked to fix? I have something similar happening to my exhaust now as well. I have a 1976 with a weber 38/38 and nice fanned out splatter in the garage when I start it. Many thanks.
Weber run at low fuel pressure. Like 2.5psi or something. I had issues with running rich until I bought an in line fuel pressure regulator and set the carb up with the correct fuel pressure. They have that information on their website. But I'm pretty sure it's 2.5 to 3.5 psi
thank you. Your feedback is perfect and makes sense. Installing a regulator this weekend along with a new oem mech pump, fuel filter, and oil change/filter. Feel like my oil has been less oil like recently so won't run it until this is installed and everything changed out. I've had my 40 since February so no telling when the weber was installed and I've never measured the fuel pressure.
