oh boy, another sm420 question...
Here again...
i just bought a new old stock 420 to replace the old one and after quite a bit of grinding the installation went very smoothly... until now that is. It is mated to the transfer case and on the truck, but it wont shift into any gears. My assumption is that the top plate was not seated properly when I bolted it on, so I took it off. The problem is that I have no idea what the gears orientation should look like when I put the top plate on. More specifically, how do I adjust the tranny to put it in neutral so I can put the top plate on. Also, the lever arm?? that sticks out upward beyond the tranny into the top plate moves very easily on my old transmission, I can't get it to budge on the new one. Is this simly because it's new and tighter? Or should it move freely as well? Thanks for the help, everyone.
The top cover shift forks have to match the positions of the gears. The easy way to do it is to have all the gears and top plate in neutral. It is easy to be sure that it is in N because the output shaft (main shaft) will turn freely while the input shaft does not. The second gear and 3-4 shift collars have a detent that make it easy to get them in N and have them stay there. It is easy to tell if the top cover is in neutral as all the slots that the end of the shift lever fits in will line up in a row.
The problem is with the first (low) and reverse slider gears, because they can move freely on their shafts. Put a dab of grease on the gear shaft to stick the gears and hold them in place while you put the top cover on. Then install a couple of bolts to hold the cover and check if it shifts freely before you button things up.
More pictures:
http://members.cox.net/cglabe1/SM420/sm420.html
Thanks guys. Pinhead, the slider gears you refer to are the ones which are attached to the fork (revrse lever?) which goes into the top cover, correct? These do not slide easily at all on the new tranny. In fact, I have applied quite a bit of pressure to get them to slide, but to no avail. For fear of ruining something I was hesitant to continue doing so, howver after seeing how easily the old shaft moves I'm thinking it might be partially siezed or stuck. Any thoughts?
there was a yellow colored oily substance on the gears themselves. There does not appear to be a coating on the slide shaft. Are you're suggesting that some of the coating, now 30 years old has bonded the pieces together? I had not thought of that, but it could very well be the case. Is there a time in the cycle of gear changes when the reverse lever should not move? If not, then I will just continue to work at getting it free. If so, I guess I need to figure out how to change the gears to get it to move.
Did you try shifting it with the original top cover?
The straight cut first gear and reverse gears need to slide on their respective shafts in order to shift. Same thing with the synchronized second gear and the 3-4 gear synchro shift sleeves. If you can't shift the transmission manually w/o the top cover then something is wrong. The coating is probably cosmoline if it is a USGI part and it gets pretty stiff and waxy. Try washing it off with solvent or brake cleaner until the all of the gears and synchro hubs will slide.
well, I think I've got it narrowed down. I put the top cover back on the old tranny just so I could verify where neutral is on both. I then removed it and placed it on the new tranny. The rear shaft spins freely- alas neutral. The truck even idles. However I can't get it into a single gear. Tranny cover comes back off and check to ensure everything moves as Pinhead stated. All of the gears move perfectly except the reverse lever gears. The reverse lever/gears won't budge at all along their shaft. How much pressure do you think is safe to loosen it up? Light taps with a brass hammer?
thanks again,
David
Well, after hours of frustration I finally got it! I used a large pipe (handle from my floor jack) put it over the reverse lever and ensued with some much needed cruiser venting. I started out lightly, but by the end I was willing to break my new $400 transmission just to get even with it. Lucky for both of us the lever finally broke free and the gears started to slide. Now, a little TLC and I should be up and running by the evening. Thanks again to all of those who offered advice. This place ROCKS!
