Official intro and some ??'s
Hood River, OR
Well I figure since I finally have a LC that runs and drives I should actually introduce myself. I got hooked on mud a few years back when I picked up an '84 fj60. The plan was to swap a diesel in to it and use it for expeditions/camping/exploring. The more I read on this and some other forums the more I learned about my newly purchased rig. I started collecting parts and tearing the cruiser apart. At this point I was a full time student working on a mech. eng. degree at GWU in D.C. I was working on the rig at my friends farm about an hour outside the city and between the drive and school the project got put off again and again. I had a couple of weeks last summer to put in some time and I came to the realization that I had bought a true east coast cruiser (read: rusty). I decided it wasn't worth the time or money that a diesel swap required on this rig. This was even after I pulled the frame and acquired another one that was/is in really good shape. I came across another '84 in PA, a few hours away, that was in pretty good shape (originally a Cali. cruiser) and picked it up as a new base to start the swap...again. School picked up again in the fall and next thing I knew the project was on hold again. I was really getting tired of never getting to work on my project and never getting to run to the hills and play (whitewater kayaking is a pretty big part of my life, I was even an Olympic alternate a few years back) with or without my cruiser. At this point I started looking for an already built rig so I could get back to playing. I saw an add here on mud for a '94 that had lots of upgrades, was a little beat up, and the price was right. I went and test drove it and picked it up a couple weeks later. The current setup is:
'94 FZJ80- ~161K
6in slee front springs
OME 864 rear springs
adjustable panhards
cc correction bushings
ARB front bumper
warn m12K winch
IPF 900MSR lights
35" Trxus tires
Since I picked it up I have not had a ton of time in it b/c I have to find/slap on some stock tires to get it through inspection. I did replace the radio with a sony xplode with a standard audio input so I can plug in my ipod. I am getting the fluids together to baseline everything (oil/tranny/tcase/diffs). P/O thought a new fan clutch was needed, I haven't had any overheating issues at all in the 200 miles I have driven so far, but it will be the first thing I do once through inspection. For fun I flexed the suspesion out infront of my house I sure enough the rear flexes like crazy, to the point where I can easily pull the spring out!
So my first question is how should I deal with this? Not really up to date with different spring setups on 80's so I am really in the dark on this one.
Next on my list of things to do is correct the pinion angles (fr. and rr.). For the rear I can whip up some ajustable uppers in the machine shop at school (part time job). The front is where I am not sure as the best plan of action. We have full CNC capability at school so I could easily enough machine some new control arms with the correct caster built in and run stock bushings -OR- I could do a 3-link setup. I will be driving this thing to baja from DC next year so I am going to see a fair bit of highway driving and I want to know if I should just stick with the stock design or go with a 3-link? Anyway that shold be enough for now... pic's to come soon.
Oh yeah.....
:flipoff2:
pic's
Here are a few:
Welcome!!!:flipoff2:
You know green is really the best color on an 80!!!
Ditto on loosing the flares and lining the lower 1/4, or the whole thing......
Yeah the flare delete/body plug/liner is in the plans for the summer, when it get hot around here to dry that stuff really fast. Right now I am trying to focus on get the mechanical stuff dialed.
still looking for some info on the rear suspension, ie: should I worry about the springs coming off -and/or- is there a fix other then limit straps.
Thanks,
Bahndo
There are some vibrations but what is more concerning is the noises I hear coming from the passenger front floor area. I was originally thinking it was the u-joint in the front DS since it is a stock shaft. The pinion on the diff. is pointing toward, perhaps even a little above the t-case pinion, so I figured that it was most likely worn out u-joints. I have been driving it more and I have noticed the noise comes and goes and is much more prevalent when the motor is cold. Upon further inspection I shook the exhaust around a bit and I am starting to think it may be the cat. instead. I am planning on dropping the front DS and driving to see if I can narrow it down. As for linking the front, as I stated earlier the pinion angles are not parallel and the caster is definitely off. It's not terrible by any means but it is a little unstable at highway speeds. From what I have read so far more caster correction is needed with this much lift then the offset bushings provide. So I have been looking into machining my own control arms, but it seems like for the money (1.75" plate steel is pretty pricey) I could do a quality 3 link and be able to keep the caster angle stable (ie: the same) thru most of the travel of the suspension. Just want to throw out what I am thinking and see what others with more experience think.
According to a recent ebay auction, this is also the most expensive and highly regarded color by the Toyota Motor Corporation! So congrats on having such an amazing color!:flipoff2::flipoff2::flipoff2:
