Media Official 35" and under!! Post pictures!!
Photo/Video/Audio threads
265/75/R16 Bfgoodrich All Terrain KO2's, OME Stock Springs, Stock Toyota Shocks.
1997 2UZ80 with 285 75 17 Toyo OC AT2 (about 34")
255/85 R16 Maxxis Bighorns on 16x7 Tacoma steelies.
OME stock replacement springs. Tons of gear in the back so it sits pretty level.
This is probably the next size tire I will run. They should be 33", correct?
What is the on highway performance like with the 4.10 gears?
Will they fit on the stock alloy rims?
A tire size converter says they are 33.3". I've never measured. Gear ratio wise I only see a difference up steep grades but it's an 80 so it wasn't exactly fast to begin with. I don't expect any difference from a 315 or similar size tire with regard to gearing but they steer lighter on the highway.
The stock 8" rim is wider than the recommended width. Part of the reason I went with the steel wheels (7" wide). I think I've see others on MUD with this tire and stock wheel but don't recal in what thread.
Just went from 33" Duratraks to 35" Kumho MT's. Both on an OME 2 1/2" lift. Heavies in the front and mediums in the rear.
33's
35's
Nice truck !! Done just right. What bumper do you have there?
Thanks! I actually have no idea who made my bumper. It used to look a bit different and i didn't like it so i changed it and added a few things of my own.
Switched From BFG KM2 35.12.50.15 to BFG KO2 315.75.16. Now to see if it was a good change...
You won't notice any difference with 4.10 gears. I drove on 35s with 4.10 gears and only noticed a slight loss of excelleration. The only driver for me to make the change to 4.88s was that I replaced my diffs with ARB air lockers. I changed the gears while I was in there.
Running 35, on the highway, no problem. Off road I haven't noticed any major change.
