Off roading with fj80 good?
Hi, I am greatly considering getting a fj80 for off roading, i now these things are slow but i hear great off roading? Are they good? I have heard yes and no, no because its full time 4X4 and i hear thats not so great? Would this be better then my 92 4runner?
yes this truck is all wheel drive but when you shift into low range it locks the center differentials and turns it to true 4 wd (also done with the center diff lock switch) you also have the option of front and rear lockers mated with solid front and rear axles and coil springs with all that on your side these 80's are unstoppable.
oh it will stomp all over a 92 4runner off road:D
If you spend several hours here and peruse the FAQ section you will be a much wiser man for it. In short id look for a 95-97, with lockers and service records. Happy hunting. Excellent vehicles, and not too bad to maintain if you do your own work. Plan on some baselining and preventative maintenance before expecting years of happy service.
i went from a 98 4runner limited to a 2000 tacoma trd, to my current ride, a 1994 fj80 and could not be happier with the off-roading ability of the land cruiser.
I sold a second gen Runner to get the LX. IMHO the only advantage the Runner had was size, it was smaller and lighter, other than that the 80 smokes it.
One thing not mentioned: the 92 Runner has IFS. The 80's are Solid Axle Front & REAR. The front Axle is a 8" w/ a High Pinion Diff. The rear axle is 9.5" FF on the 93+. This, coupled with the coil spring suspension is MUCH better than a 2nd Gen Runner. Coil is like the mid point of comfy between Leaf Spring & Torsion Bar suspensions.
If you get an 80 - make sure it's got the 4.5l (1993 up) - and LOCKERS!
Good luck!
John
Good luck!
John
Ain't nothing wrong wit a 3fe! While I have the 4.5 I have driven a 3fe and its not that bad. I don't think they have the HG issue either. Also been told if you wheel it hard and the factory lockers break its hard as hale to fix. I'd get an ARB locker up front and Aussie rear or 2 ARB air lockers. What say u?
an 80 is leaps and bounds better off road than a 2nd gen 4runner. of course it all depends on the driver, but same trucks not locked...the 80 will win. find one with lockers and you'll be that much more ahead of the game. i had a 98 runner, and it was fairly built...equally as built as my 80. it wheeled awesome with both ends locked..but the front IFS on the runners are just the weak point. not that i broke my ifs ever...but it does take its toll on it for sure.
go 80 or go home.
If you're wheeling it, then you shouldn't worry about what motor it has. A 3FE doesn't make it any less of a Land Cruiser. I feel that many of these guys are saying just the opposite. The F-series motors are the ORIGINAL Land Cruiser motors. There's no argument there, period. Plus, you can easily swap locked axles to a 91-92.
I'm tired of seeing all the 3FE bashing. I'm 20, I should be into FAST cars, but I drive a 3FE, and I LOVE it. :flipoff2:
Glad I got that off my back.
Now that being said, F/R lockers, plus the FF (full-floater) rear axle, came factory on 93-97.
the Land Cruiser is the most cabable rig for sure, I have wheeled with range rovers, discos, and Jeeps and pretty much everything else, and it will amaze you at what the Land Cruiser can do stock, especially if you have lockers, its invincible!!
This isn't meant as an insult, but if you want to know if it has 4x4 gearing you might want to get a rig other than a Cruiser first, and learn how to wheel. Then step up to a Cruiser once you are capable and confident in your abilities. :D
I might get flamed for saying this, but I don't care. Become a good four-wheeler and you could drive anything. A person could still suck, even in a Land Cruiser. ;p
Besides I now kind of wish that I had started with something a little harder to drive, and then moved up to the Cruiser, because sometimes I get a little cocky about driving the best vehicle ever. I don't know what it's like to wheel without lockers, so I have to retroactively learn how to pick lines. Sure, I don't always engage my lockers, but I still have that safety net. So I guess you should buy a Cruiser with lockers, and not use them very much.
Good luck!
John
Just an aside - 2nd gen 4Runners are coil sprung in the rear.
I had to do a lot of mods to my 92 4Runner (22RE) to get it to the same off-road capability as a STOCK locked FZJ80.
Both are great trucks, and both are capable of amazing off-road ability, but the Land Cruiser is better "out of the box", having features simply not available on the 4Runner.
Not only the solid front axle, optional lockers, and four coils, but the full-floating rear axle, disc brakes all around, and much more room inside.
One thing I think the 'Runner has over the Land Cruiser is its size. Depending on the kind of wheeling you do, a smaller vehicle is sometimes better. the 80 is HUGE.
Another thing, of course, is the gas mileage... :doh:
Here's my 4Runner (now sold but I want it back):
And here's the mighty 80:
attachment.php
Both are great vehicles; you can't go wrong either way... But I figure there's about $5000 into the 4Runner just to get it up to par with the Land Cruiser.
Asking HP numbers, etc simply broadcasts that you are ignoring the suggestion to read the FAQs many here labored to create. In 30 minutes of reading you'll know more about the 80 than 50% of the people on this forum, grasshoppa.....
I've driven 4Runners from 88-94 on hardcore trails and also LandCruisers from the same years (all new vehicles) on the same trails as part of a product evaluation program and there is no comparison as to their trail prowess. An FE engined 92 80 will walk all over a 4Runner without breaking a sweat. Make the trails harder and the gap widens until you're breaking stuff on the 4Runner and the Cruiser is sweating. No comparison. The 93+ models have better power and other things, which you'll read about. Current pricing of the older FE models vs newer FZ models does not justify getting the older one as the newer models are now so cheap. JMO.
DougM
