OEM Shocks
:bang: which really doesn't mean anything since Toyota only recognizes Land Cruiser in there parts system back to 69. Could mean it changed in 69 or it really fits older. Looking at SOR's site it shows only one shock for the front but says back to 58 while the FJ40 started in 1961. Rear showed a change in 1/75 which is when the 75 model started. :meh:
The part numbers given above are the most current superseded numbers, but you brought up some good points. Let me summarize what I think:
1) The front shocks will for sure work for trucks going back to '69. Based on SOR's site, it will most likely work for all earlier years as well.
2) ToyotaPartsDeals.com shows the above part # for the rear shocks as being good for '69 onwards. I'm pretty confident it will work for '75 onwards; however, I don't know if there is a difference prior to that.
Bilsteins are more than that, but the ride is superb.
Bilsteins cost more than twice as much, and based on what I've heard I'm sure it's better. Arguably, my original Pro Comps shocks are better. However, like many things with the Cruiser, you can modify the original to make it better, or you can stay stock and enjoy the OEM experience. In my case, what tipped the scale is a silly reason you probably didn't expect: Stock length Bilsteins only come in yellow. I'd rather not have yellow shocks on a yellow truck :)
Did a quick look at a early 63 I have under a tarp. The difference is the pin on the earlier one is mounted to the bracket welded to the axle instead of the plate under the springs. That would make it distance to the pin on the frame tube shorter which I believe would require a shorter shock. Better protected above the spring but also restricts the travel the shock can have.
I rattle-canned the HFS steering damper, but I didn't mind the yellow shocks. When people say that you can't make a short wheel base vehicle drive nicely, I kinda laugh to myself.
If you can measure the length of the shock in the '63 it should be easy enough to compare.
This was junkyard rescue the rear axle was gone when I bought it and put in another early centered axle like it would have been in there. No shocks. I have a few other vehicles pre 75 in town but none have OEM shocks that I aware of. To do a real comparison would need the shocks loose to compare fully closed to fully open. Measuring the outer metal cover doesn't really tell you much on a non OEM shocks. Would be interested what Onur (Beno) finds out about shocks. Be curious if the part number from a 3/69 wasn't just superseded to the later part number on the front. My guess is there will be a completely different part starting with 75 model in the back as the anchor changed enough to cause it.
Fast Eddy you and Racer65 arent that far away. I think Racers '79 40 is the smoothest one ive ridden in. Let me know if you all are interested in meeting up sometime to compare. Im currently having one leaf taken out of my medium ome suspension.
For anyone who references this thread in the future:
Front shocks: Part # 48511-69037
Rear Shocks: Part # 48531-69059
Rubber bushings are included.
Resurrecting an older thread rather than starting a new one. I just received my OEM shocks today and I did have one question, regarding the bushings that are included.
I'm hoping this falls into the category of there's no such thing as a stupid question, but why are there four rubber bushings??
One per side of shock for both upper and lower. The bushings are 2-piece bushings, tapered side towards the inside
-J
I'm happy with my Toyota shocks for a '75 40. When I took the old aftermarket shocks off, one of them was seriously pressurized and made a big oily mess all over everything - I'm glad that I avoided injury.
Hello all
Does anybody have experience with the dimension of those rubber bushings - are they the same geometry at front and rear for factory j4?
I recently ordered some replacements from SuperPro, which according to their homepage should fit for my 1983 bj46, but they actually don't fit because the inner hole diameter is way too big with 19mm --> The ones I have currently are more like 16mm (front and back are the same from what I gather). Do you think my setup is still factory or did the PO possibly make some modifications? Looking at the picture shown by @tlaporte above they look similar to what I have currently installed...
The reply I got from SuperPro was that their bushings are the correct ones and that front and read should be different...
Thanks for any insights.
