oem radiator clamps
sea bass
10 Year
I'm replacing all my radiator clamps with Toyota OEM constant tension spring clamps today
The spring type go on the top hose and the screw type go on the middle and lower hose
Cool. Does anyone know if the constant tension clamps will work correctly with silicone hose?
AFAIK constant tension clamps are preferred with silicone hoses because silicone rubber never fuses to the metal pipe as rubber does.
Thanks. I was wondering if the thickness of the silicone hoses are the same as regular hoses otherwise I could see an issue arising.
The OD of the aftermarket hose could affect the tension of the clamp on the hose if the OD is not close to the OEM hose OD. An option would be to use Breeze Constant Torque clamps, a variation of a worm-screw type clamp.
Breeze - Breeze Constant-Torque® - Breeze Hose Clamps
I have often wondered when you guys go to Breeze clamps how do you set the correct torque, seems like it would be difficult given some of the locations of the clamps. OEM hoses and constant clamps seems like a much easier and proven method.:meh:
I also prefer the OEM clamps where they will work (still using the original OEM radiator hose clamps on new Toyota hoses) but sometimes they won't work as well if using a non-oem hose as the OD may not be the same as the OEM hose. Or like the OEM clamps that were (from the factory) that twisted wire thingy, like on the original PHH which is often replaced with a Gates hose and Breeze CT clamps. Sometimes I use what I have on hand, like for the short hose sections going to the heater control valve. If they leak a bit after installation I tighten the Breeze clamps up a bit more until they don't leak being careful to not overtighten.
