Oddball backup light switch
Tampa, FL
When I built my 71 FJ40, I converted the stock 3-spd column shift to an old aftermarket top-loaded 3-spd floor shift that was originally made/for by Downey Toyota. Although the top plate has a tapped boss for, what would appear to be a male-threaded plunger-type switch, the OEM Toyota switch for a floor mounted shifter is too large to thread into the hole. Has anyone had any experience with these or know what could be improvised, beyond mounting a rocker switch on the dash or shift rod? These adapter kits were popular back in the 70's and early 80's when there were a hell of a lot more of these rigs around.
thanks
thanks
Are you sure your reverse light switch isn't for a later four speed? The FJ40 didn't have a reverse light until the 68 model and some top plates do not have the threaded boss. Those that did would think were taped for the three speed reverse light switch.
Most backup switches are simple closed or opened switches and assuming you can find the appropriate sized (thread pitch, diameter and length) switch...you should be able to make it work with your toyota harness.
I suspect that the switch I bought that doesn't fit may be for a later cruiser but since the conversion kit was made by or for Downey, it probably used something not OEM. This is my 2nd 71 FJ40 and I also converted the original one from column to floor shift. Did Toyota offer a floor shift in 71?
Jim @Downey is on here and should be able to answer the question on the switch they used. The cover was available from Toyota and doubt Downey made a cover that took a odd ball switch. The three speed and four speed were different. Not sure but my guess the 40 series five speed switch is different than either. All three switches were in different locations on the top plate.
When I converted from column to 3 speed floor I used a factory top plate and the backup switch was located on the back of the shift tower. The Downey top plates I have seen were not taped for the switch. But the boss was cast in so you should be able to drill and tap it out. As @Living in the Past said I would get in touch with @Downey.
JP
Ok, I'm here. Originally Downey sold floor shift conversion kits made up of entirely genuine Toyota parts. Then as the cost of the top aluminum housings went way up in cost, we made our own top aluminum casting, BUT without the mounting boss for a reverse light switch because that would have caused (a) twice as much to make the mold and core box, and (b) twice as much to buy each casting. It is remotely possible that the smaller hole for mounting a PTO winch shift lever is being confuse with a hole for mounting a reverse light switch?????
That makes sense, never thought about that since the column shift cover had that threaded hole as well.
What about locating and installing a Toyota housing with the accommodation for a reverse switch plumbed in already. Plenty of them around.
For reference here is where the reverse light boss is. Use this one to check angle on shift canes for a five speed conversion. This one came on a three speed transmission, transfer case and PTO I bought at a wrecking yard years ago. The shift cane was cut and the transmission was full of rusted gears. For the price with a good transfer case and PTO I did okay.;)
That's entirely possible in that the boss is located on the side of the top plate, which really wouldn't correspond to the "H" pattern of the shifter. I guess you answered my question. Thanks for your input.
