- Joined
- Jan 5, 2015
- Threads
- 9
- Messages
- 35
93' FZJ80 with a OME medium springs, armor, rack, ARB bumper, and tire carrier (for reference) and the 2.5" caster correction plates.
I've been dealing with some front end vibration (65+ front end growling/slight vibration through car)and have removed the front driveshaft to try and track it down. Of course, the vibes disappear and I've also noticed some stiff points in the U-joints.
I took some measurements of the driveline angles (see below), and it seems a fair amount off (~3.4 deg). Specifically, the transfer case appears to be tilted upward (front output flange pointing towards hood). Am I right to assume that the transfer case outputs should be parallel to the ground? Could this be due to worn out engine/transmission mounts?
Any input welcome! Bonus pic of the 80 in the middle of the Bonneville Salt Flats!!
