I've had no problems with running the ac on several beach runs. No wind in June/July on a hot day, and you'll appreciate the ac(specially on the backroads. I did give the cooling system a good once over before i put it on the beach for week long camping trip. spray a bottle of simple green on the radiator and coolers, a good backwashing does wonders to get all the gunk and crap out of the fins. New Tstat, fan clutch, hoses, flush and toyota red/distilled water. Mine will probably get a flush and fresh coolant this summer. I average anywhere from 150-200 miles on sand each time we go to the beach. If it has rained alot, i wont bother airing down. I usually try to stay on the harder packed areas, rather than the really soft stuff.(I did the 5 hours of digging and jacking when I was 19, dont need to do that anymore) I'll either use momentum or drop down to lo range if i feel the need. I also really pay attention to the tide lines, because some areas are impassable at high tide. When we go to ocracoke, i drop down to about 15-20psi when we get into town, and air up when we head off island. Some of the areas we go run about $750.00 minimum for a tow, so brains far outweigh the skinny pedal. The most nervewracking parts of the drive to me are the ramps coming off the beach. Always super-soft, always rutted, and sometimes blocked by a rented minivan full of Estonians buried up to the door sills(funny thing, they made it out onto the beach, turned around, and were heading back up when they got stuck).
Make your turns as wide as possible, and stay at a constant speed. As was said above, there are only a few places out there that are bad. Most of the beach is a pleasure to run. Drive like ya have an egg under the pedal, both on acceleration and on braking.
Nice thing about a cruiser is that its about the same width as a full size pickup, so the tire tracks are about the same width. I hated trying to run the ruts in my taco, because it would bounce from side to side. Its not bad for a short run, but after 12 miles of it, it gets old.......
One thing you may want to do is make some screens for the door windows. Keeps the skeeters and greenheads out, and quite a bit of sand.
Keep a 5 gallon bucket accessable, and use that to let your passengers dunk their feet before they get in the truck. That washes alot of sand off. It can also be used to hard pack areas around the tires for traction.
