OBDII conversion
slow95z
Always parting 80s
Dublin GA
what all needs to be swapped to make this happen? reason i ask is i am putting an engine in a 93 that came from a 96 and the 93 has a bad heater core (which is what caused the bad engine) so i will be ripping half the dash out anyways. i have 2 trucks that were ODBII so i should have all the parts i need.
other than swapping the drive train, ECU and some O2s what behind the dash needs to change? is the entire dash harness different? am i wasting time even thinking about this? i love my 94 truck just as much as my 97 but to get this 93 to work with an OBDII reader and possibly a little boost would be nice.
I just swapped my 1996 engine into my 1994 Landcruiser. I found it was not worth the extra work to swap everything over so just did the long block. I had a few helpful gurus from this board message or talk with my by phone to sort out which direction was best. In the end, the route I took was the fastest and easiest route to go.
well yeah, i know the long block is faster but i thought i would ask since i will also be removing the dash and will be one step father in.
Well, i imagine that one of the points where things get sticky is where the OBD2 ecu expects to talk to a TCU for a A343F rather than the A440F TCU.
I'm not certain that's an issue, but, it comes to mind.
Get the 94 and 97 EWDs and compare notes?
I'm sure it's possible. Might be some cut and splice for instruments.
The OBD2 exhaust system is different wrt the o2 sensors, as you noticed. You need a pre-cat and a post-cat. And there's a chance that the OBD1 cats won't make the catalyst efficiency code happy.
you must have missed the part where i said swap drive trains ;) i would obviously use the A343F as it works with the OBDII system so that is not an issue.
Ahh, yup
.:Sent by pneumatic tubes
Entire dash harness is different. 93-94 has 3 connectors from the dash to the engine harness (Ih1, Ih2, Ih3), and a separate A442F TCU module with two plugs for the trans computer, which is conveniently located near the driver's footwell. 96+ only has Ih1 and Ih2, (IL1/IL2 on LX450), and the A343F TCU is integrated into the ECU.
Additionally the Circuit opening relay, fuel pump control, ignitor, tach signal to the gauge cluster, some of the shift indicator wiring, 2nd start, and other cluster wiring is different.
So without having to heavily customize things (which is basically what I'm doing putting a 94 front clip and engine harness into a 97 LX chassis harness) your best bet is get a complete 96+ front clip harness with fuse block, complete 96+ dash harness and 96+ gauge cluster. This poses obvious problems for all of the dash switches and hardware as well.
Alternately, strip the block down and throw all of the OBDI stuff onto the 96 block. Other than the extra crank sensor in the oil pan my understanding is that everything will bolt up.
ok, i knew it would be a bit of work. guess i will just swap my intake and exhaust onto the later style engine and go that way. dash harness i could deal with since the dash will be out but swapping out the fuse block and everything else is just a bit much.
