OBD1 FZJ80 93/94 O2 Sensor wiring color
Tucsonistan
Both my EWD and FSM make it unclear what color wires ( harness side ) match up with the colors on the OEM sensor side ( 4 wires; red,blue,white,gray) Nor can I find NTK literature designating each color wire on the sensor side for heater heater signal and ground. Can someone provide me a photo of a factory harness plug and the wires in each associated number pin out? I recently replaced my sensors with new OEM and relocated to my manifold and now have a code 21&28 something I haven’t had before. Anything helps thanks
Isn’t the pin out in the OEM EWD?
appreciate this. this is how I have everything hooked up and yet still have 21&28 codes. Ive triple checked this now. Tested sensors both have good OHM
Verify that pins 1, 3, and 4 on both O2 sensors are getting to the proper pins on the ECU according to the schematic.
Verify that pin 2 on both sensors are getting +12.
Pull the 15 amp EFI MAIN fuse out of the relay box on the left fender and allow the ECU to reset and clear all codes. Takes about 5 or 10 minutes.
2 ( yellow red) 12V + [ battery power ]
1 ( gray) .007V - [ ground ]
3 (blue white) .75V [ heater circuit ]
4 ( black yellow) 1V [ heater circuit ]
You should be checking continuity from each O2 sensor to the pins on the ECU for pins 1, 3, and 4. Not voltage.
The idea is to make sure the correct pins from the O2 sensors are getting to the correct pins on the ECU according to the schematic. Checking voltage tells you nothing.
Here is my attempt explaining the layout in 3D from the ECU/Harness side.
(1) HT - Orange or Gray (H8)(2) B+ - Red/Yellow
(3) OX - Black or Blue/White(H8)(4) OX+ - Yellow or Yellow/Black(H8)
Note the 2 positioning slots on the O2 clip compared the the image in the post above.
EDIT: this is from a site selling the OEM (89465-69115) O2 sensor, each manufacture uses different colors, sadly, they sometime use the same color for all 4. Your mileage may vary.
(1) HT - WHITE(2) B+ - BROWN
(3) OX - BLUE(4) OX+ - GRAY
