O2 Sensor Question
Olean, NY
I need to get an O2 sensor for my 1996 FJ80 and I was told it was the one in front of the converter, which through autozone it is $123.99 the other O2 sensor is less expensive (the one behind) but evidently the more expensive one is bad. Where should I buy a new one and who has the best price. I have had about 4 people tell me four different things, so I figured I would put this out to the experts. (You folks.) Thanks for any input you have.
Call CDAN at American Toyota -1-800-432-6668....it will be your best bet to stay with the factory O2 sensors.
Remember to tell him you are a member of IH8MUD!
Good luck
Steve at Man-a-Fre can assist too. They sell both aftermarket and OEM. I would go with the OEM (as I have tried both) and the OEM lasts longer, where the "am" gives bad readings.
Best of luck! :cheers:
This old post should make the decision easier. The one AutoZone sells for our trucks has a ceramic heater, it doesn't take the current flow the original heater did, so you'll get a fault and the fuel mixture won't be adjusting properly. The heater is only used when the exhaust stream isn't hot enough, when you first start and at idle.
https://forum.ih8mud.com/80-series-tech/89849-cdan-right-oem-o2-sensors-better.html
Good luck
X500
Do yourself a huge favor and go with OEM O2 sensors from CDan. Aftermarket O2 sensors will only cause you problems 99.9% of the time.
Dan is at Rubicon, but his excellent staff can take very good care of you!! Great service and prices on OEM. I ought to know regarding O2 sensors. I've replaced mine myself twice!
dam i forgot to reset the computer. hopefully my gas mielage will improve.
read in the paper that the best way to drop 40 to 80 cents a gallon is to regulate the brokers that trades stocks!!
