Nutserts for subtank installation??
I am looking for nutserts for complete my subtank install. Any reason these won't work?
Material Type
Steel
Finish
Cadmium-Plated
Steel Type
C1010-C1110 Steel
Type
Nut Inserts
Thread Size
M8
Metric Thread Pitch
1.25 mm
For Material Thickness Range
.030" or thicker
Drill Size
14.28 mm
Drill Size Note
Drill size listed is for material with a 0.030"-0.090" thickness. Thicker material may require larger holes.
Body Diameter (A)
14.26 mm
Dimension B
15.62 mm
Dimension C
8.26 mm
Dimension D
.38 mm
Installation Instructions
As the insert is installed, the threaded portion is drawn into the sleeve, creating pressure against the hole and securing the insert.
Pic? There are big differences between threades inserts. If I was mounting a sub tank I would try to find a different method first. I know that this is the accepted method but it makes me nervous. That said, I like the ones that are zinc plated steel with splines like a little axle.
Romer has a pretty extensive thread on his subtank install...Have you read it?
