Nut and Bolt Logic... will it work?
Utah
I've been lost in the forest of fastener nerd-dom seeking an answer to my question. I've found some mind blowing equations through google searches, but in the end I am really working off approximations with the materials I'm using so I haven't found a clear answer. I'm looking to you guys for real world experience and advice.
I want to mount the bumper with swing out tire and cooler carrier to my rear frame cross member with hidden fasteners. I'm wondering if 9/16" (3/8" spacer, 3/16" bumper) of mild steel tapped will hold the load with 6 to 8 7/16" fasteners spread out across the frame member.
I know I could use a cut out for lights to hide the bolts, but I found some surface mount round lights that would work good for paying tribute to original status.
By 3/8" spacer, do you mean you are backing the crossmember with a slab of steel and plan on tapping the steel instead of using nuts?
Yes. I would weld 3/8 plate to the 3/16 thick 2x4 tube. Then locate, drill and tap all the way through totaling 9/16 worth of steel. I’m also considering sandwiching a weld nut between the two pieces.
Rule of thumb is minimum one diameter of thread depth, so 7/16 of thread would be minimal for 7/16 diameter thread. The 9/16" thread depth would suffice. The more important aspect is the leverage of the tire etc. on the mount. Use every bit of vertical surface area you can, as well as gussets to counter act this force. I used three groups of 4 grade 8 1/2" through bolts with nuts. The cross member itself is the only thing that flexes/twists.
Like this basically
