not moving in reverse gear
I bought a 97 auto turbodiesel with 100K and no service history available 2 weeks back. Been using it since and repairing as I go along. Put new shocks and nozzles etc. All of a sudden, i can engage reverse gear but it moves with great effort and front wheel catches jerkily as if the brakes are still on or something is jamming it and releasing it every few inches. And there is a loud grinding kind of noise. Moving forward is ok only reverse has this problem. what's gone wrong? can anyone identify?
I think some more info would help. For starters I would not drive it until you figler out what's wrong with it. Also, I'd get on an incline and let the truck roll backwards to see if you can detect anything binding.
And I presume this with any backward motion? Are you full-time 4wd or do you have lock-out front hubs? If full-time 4wd, and it's when backing and turning sharply, it sounds like, MAYBE, you've got a center diff (viscous coupling) that's having some issues. Could be dry birfs too but that would not bind.
Start with that stuff and give us some more detail on the circumstances of when this is happening.
:flipoff2::flipoff2::flipoff2:First, WELCOME!:flipoff2::flipoff2::flipoff2:
If it's fine in D and jerkey in R I'd say check the E-Brake.
Welcome.
Have you checked the brake caliper bolts?
Is anyone putting a dab of threadlocker on the bolts now?
I'm actually starting a birf service tonight as well as brake job and figlered since this is a potential issue I'd put a dab on.
I think the key is to set the bolt at the correct torque (90 ft-lb). I remember that there is not much room to get the torque wrench in there on the top one. (A 3/8" drive torque wrench with smaller head might help). Have fun!
