Not charging unknown cause
nw montana
battery keeps dying. ammeter when running doesn't go to the positive side as usual. It does go negative when lights are turned on. pulled alternator and Had it checked and its checks okay. put another voltage regulator in from running fj55 and still no positive needle on ammeter when running. battery holds charge overnight. all connections seem clean and good. all fuses seem good.
not sure what to do next:confused:
this in on 77 fj45.
any ideas?
thanks for any thoughts.
Jay
If fuses and connections are OK, then do a continuity check on each wire coming out of the alternator to make sure it isn't broken between connectors, do the same with the voltage regulator. See your FSM for the appropriate wiring diagrams.
I jump started it, drove it home and charged it all day. then took charger off. next morning it had 12.74 volts. slowly over next 2 days battery got weaker again and still no sign of charging. I'm guessing its in the wires too. I guess the FSM indeed is the place to start.
good idea, checks out good. thanks
You may have a bad ground or a shorted wire that is slowly draining you battery.
But that doesn't explain why the ammeter goes to negative when the lights are turned on. I'm not saying that this is not a contributing factor, but the alternator should keep up with the lights as long as the rpms are above 1000.
For some reason, the "flow" is not going into the battery. 3 possible explanations in my opinion.
1. Alternator is not putting out a charge (but you got it tested and it appears to be okay)
2. Battery will not accept a charge (i.e. bad battery - I would get it tested if I were you just to rule this out)
3. Current flow is interrupted somewhere between alternator and battery - a wire is broken or grounding out somewhere.
Getting 1 and 2 figured out leaves you to get acquanted with your multi meter. Pull it out and start testing your wires.
Good luck! :cheers:
If your alternator is not gounded via engine block, ground strap, etc. it will have all the symptoms he is having. The alternator will put out voltage even when it is looking for a ground.
My Alternator on my tow rig was putting out 19.8 volts because it had a bad ground. Batteries would go dead after two days. Amp meter would go to - when lights were on, etc.
I'm not saying that is his problem, just a possibility.
I replaced the alt and volt regulator, only find the battery was bad, even though I had just bought it a month earlier... .
