Noob t-case
the factory service manual would be the first step.
off the top of my head, ~109ft#s on the output stake nut.
a good socket set, box end wrenches, and a mallet should pretty much get you through... but all this only aplies to the one-piece case.
good luck! carl
You have got to look at the units of measure that go along with the numbers. My guess is that the 1/2 inch drive 20 - 150 is measuring ft-lbs. The 3/8 inch drive 20 - 250 is measuring inch-lbs. 12 in-lbs = 1 ft-lbs. 250 inch-lbs = 21 ft-lbs. These two torque wrenchs cover completely different ranges in torque. Therefore, use the 3/8 in drive for low torque applications (small nuts and bolts) and the 1/2 in for higher torque.
I have torque wrenches with these same ranges and they pretty much do everything I need. You should keep them both.
