Compared to Pirate 4X4, were Gentleman.You said gentlemen.........HA! Not here.....
pull the OEM assembly out and put in a Wagon gear conversion with a CB antenna and a splitter.
whatever you do, don't lose the rubber grommet as they are completely unobtanium.
Just to cover the simple basics:
-Does the antenna go up/proud of that nut when the radio is powered (also, do you have the stock radio?)
-When you key on & power the radio, can you manually get any portion of antenna mast up using the antenna up/down switch on the dash?
My bet is at least the top section of antenna is snapped off, unless you say the chrome ball/end comes out on top of whatever hot mess comes out of that hole.
OK, new mast is here. I followed this video - - but am running into a snag. In the video, it shows the cord coming out with zero resistance. However, on mine, my cord isn't coming out. I tried a decent yank, but still no luck. Any tricks on how to get the old mast cord out?
Mast bezel part number. For a '95.
86392-60040
Rubber grommet thing.
