Noob center diff questions.
Hillsboro, OR
My brother bought a 1995 fj80. I drove it around the parkinglot in low gear with the diff light and abs light on. Now it doesn't turn off when put back into high gear. Does anyone know what the problem is. I'm in the doghouse here and being blamed for breaking it. He just bought it yesterday. If I drive it around the block maybe it will unlock?
Trevor
'93 locked up ZJ
It should be fine. You only need the diff lock switch if you want more control of when it locks.
The CDL switch allows you to lock the center diff when the transfer case is in high range. This is a nice feature to turn of the ABS brake system when you are traveling at higher speeds on dirt roads. If you want the center diff to be unlocked when the t-case is in low, I think that you will have to perform the 7 pin modification-someone will need to confirm this.
Tell him (it's true) that we have at least one wacko - er, I mean member - around here that likes to drive all over (freeways, parking lots, whateve) with his center diff. locked.
So; no, you didn't hurt anything.
Yeah, my truck came with a seized viscous coupling so it was basically centre-locked. Apparently the PO drove it like for six months before storing it. Then I drove it another month like that.
No damage at all. Lots of skid-marks in my parking garage, though :hillbilly:
