This is the first time I 've posted and I would appreciate some assistance. I've always admired the FJ40/43 but never owned one. I grew up with solid lifter, carbureted 1960's pickups and have rebuilt a few engines and carburetors in my time and we have a well equipped farm workshop. I recently purchased a 1977 FJ43 from a relative who brought it home from South America after retiring from the DEA. He'd had a lot of paint, body and interior work done but the engine appears fairly stock from what I can tell except for a more modern electronic ignition. There is no documentation. These past few years It has been rarely driven and takes a lot to start it. If it starts it seems to run very lean, backfiring through the carb and occasionally through the exhaust despite a few efforts to make adjustments. It also gets hot enough to make the exhaust manifold glow red if it is left in a fast idle for 10 min or so. So far I've drained the gas tank and replaced the fuel and fuel filter and vacuum lines (There are very few on this non-US vehicle.) I have plans to rebuild or replace the carb. The carburetor appears to be a stock 2 bbl with a banjo type fuel return on the side adjacent to the fuel line tap into the carb. However the bolt that holds the banjo style fuel return is hollow with a small hole drilled on the side. It does not appear to have any other metering device / valve inside as I've seen described. I cannot determine if carb rebuild kits have this or if this part is available to purchase separately. Most of the new Chinese carbs have a hole on the side that could be drilled and tapped for this bolt to hold the fuel return line but I would still possibly have a faulty fuel return metering bolt if I use the one I have. Please let me know your ideas. I will try to attach photos soon.
