NON-OEM Radiator Replacement recomendation
Nomad - www.wegonow.net
I searched. I admit, i may be a bad search-er......
On with it
I'm getting ready to put all that "stuff" back under the hood after replacing my head gasket. I want to replace the radiator and associated "stuff" with it strictly as a preventative maintenance dealio..
OEM rad is pretty expensive. Where have you found reliable replacement radiators at a decent price? Or, should i just spend the $$ on OEM stuff.....??
thanks
Have a nice day.
The PO of my rig put in an aftermarket radiator and had issues with it so ended up having to go with OEM. It ended up costing him more $$ in the end. I would go OEM from the start.
I don't know that I personally would replace the radiator as preventive maintenance unless there was cause for concern. If the core looks good and it holds pressure then throw it back in and save your money for another day.
OEM radiators are expensive...but they are far better by almost all accounts on this board. Call CDAN at American Toyota for a replacement.
thanks everyone. i will get it checked out and return to original position.
