My AC idler pulley was sounding terrible, and I did not have time to source the 6301 sealed bearings and replace, so here's what I did.
Hope this helps someone.
- Remove tension from idler pulley and remove pulley.
- Remove snapring from pulley that retains bearing.
- Using a pick between the outer race and the plastic bearing seal, remove seal.
- Pack bearings with appropriate bearing grease.
- Push/snap bearing seal back in place.
- Re-install snapring.
- Re-install pulley.
- Tension belt.
