Noise in rear please help!
I have a 95 LC 115k miles and i hear noise coming from the rear,its a cluck and squeak sound only when going over bumps and pot holes, other wise no noise. I have checked everything i can think of including rear brakes and drums, I changed the shocks on all four wheels, the springs look ok and have rubber gromets and i checked bolts that are between the seats and rear doors from inside the car looking dow. I have adjusted rear brake shoes inside drums, any other suggestions? please help and thanks in advance.
I'm trying to find a high pitched squeak from the rear right now. I think it is sway bar bushings.
Have you checked the panhard rod? It will "clunk" going over bumps if it is even a tiny bit loose. It takes some substantial torque to get that thing tight.
-B-
Panhard Rod, commonly called a "track bar" (in red):
(image stolen from Wikipedia)
Does your e-brake function properly? Mine made a bunch of squeaking and clunking before I fixed it.
Holy crap! I have the same noise from the rear drivetrain. `96 cruiser, 117K. When the rear axle goes over a bump, you hear the squeak. Thought I just had to lube the driveshaft, but did not help. I had my e-brake "fixed" two years ago and had some issues before with it locking up. Seems perfectly reasonable this could be the source of the noise. Will have a look -- thanks all as usual.
