Noise from transfer case?
bellfower ca.
yesterday i took a 100 mile trip to the mountains in my 91 80 series. during acceleration and deceleration it was fine. its letting off the gas between those i get kind of a growling sound. almost like a bad bearing in the transfer case. any thoughts?
Agreed. Sounds more like a u joint symptom.
I did just swapped out both axles and double checked the bolts. Everything there was fine. Definitely coming from the front. Next I'll remove the front drive shaft and run it with center diff locked and see if it goes away
Most likely a worn slip yolk on one of the driveshafts. In the sweet spot between acceleration and deceleration when there's little to no load on the driveline, if there is play in the slip yolk, the 2 halves will tend to flop around and create a buzzing sound.
Thats what i was thinking too. Ill check it in a bit
I'd put money on it being driveshaft related, rather than transfer case.
I hope so. I can fix a drive shaft issue easily. Front drive shaft was nice and tight. I dont think its a u joint on it. I'm pretty familiar with the sounds they make. This is kinda like a growl
so i put the front shaft on and took the rear off. no more growling noise. rear drive shaft felt nice and tight too. so now its either the rear end or the output shaft of the transfer case maybe. any thoughts?
Quote Reply
Report Edit
@yubtripn
Remove formatting
BoldItalicUnderlineStrike-through
Text colorFont familyFont size
Insert linkInsert imageGallery embedSmiliesInsert
AlignmentListInsert table
UndoRedo
DraftsToggle BB code
Write your reply...
Post reply Preview
Attach files
Share:
FacebookTwitterRedditPinterestTumblrWhatsAppEmailLink
Forum software by XenForo® © 2010-2020 XenForo Ltd.
Thread Filter by AddonsLab
Did you check both those items for lateral movement?
The universal joints should be tight and smooth throughout the range on both axis.
The slip yolks should have zero rotational or lateral play.
Ensure the shafts are in correct phase, which on my 93 is opposite each other. The 91's could be different tho. But mine exhibited the same behavior after some tranny work. The shop had both shafts completely backwards in the truck and it sounded like an aluminum bat fight.
The drive shafts were never disconnected from the transfer case when i swapped axles. I upgraded my axles with 96 e lockers. I believe both the shafts had the slip yoke toward the diffs. Is that how yours are?
I just checked my photo gallery and i was wrong. The front driveshaft yoke was toward the diff. The rear goes toward the transfer case. I wonder if the rear needs to be swapped?
After looking in the manual it shows to be right. But i have another idea. I pumped some grease in the zirk fitting after doing the axle swapp. I wonder if its too much and causing this problem?
No. Both my yokes are forward, to the front of the truck. One shaft is in phase, the other out. Don't recall which is which tho. But if you didn't disconnect the shafts from the t-case, and neither of them came apart fully at the yoke, then I don't think anything has changed in that regard.
It would be strictly axle related now, I'd think. You mentioned the sound went away when disconnecting a shaft? Head in that direction....
Could be. Too much grease would press against the pinion bearing in the third member.
So far its not the drive shaft and doesn't seem to be the rear diff. I chalked the front tires and lifted the rear end. Put it in gear and the noise is coming from the transfer case front output shaft. Wierd when my rear driveshaft is removed i get no noise at all. I only get the noise when running both shafts or just the rear shaft.
Right. I had the same issues. Try making a phase change on the rear shaft and see what happens. You may need to try a change on both, but only one at a time, then test for improvement between each change. Be sure to revert the previous change before making the next for continuity. Check the u-joints for tightness. Mine are vintage 93 and the rear shaft has a quite tight u joint. But once I got the phases and orientation right, all my sounds vanished.
OMG!!!!! I just drove this thing to a 4x4 shop in my area to get another set of eyes on whats going on. "I FEEL SO STUPIS!!!!" While doing an axle swap i decided to build nee links with johny joints. The mechanic pointed out my pinion angle was way off. It was literally 10 degrees pointing down. Adjusted the pinion and all is perfect.
Thanks for all your help guys
