No Turn No Flash
Illinois
Cruiser Gods I need your guidance
Need help my 93 Cruiser the last few days has a problem, no turn signal and no Hazard. Bulbs are all OK, fuse (turn signal) is fine. Need some guidance before taking the dash apart. Any advice on where to start? BTW rig is all stock.
Thanks in advance
Matilda,
Are these the only two items that are non-functional at this time (Mainly concerned about the horn and/or the wiper/washers)?
If these are the only to defects, check one or both of the following: Turn signal flasher and the hazard switch (both are covered in the FSM; BE15).
To check the flasher, connect + to terminal 2 and - to terminal 3 then connect two turn signal bulbs (in parallel); bulbs shoud flash.
To check the hazard switch, you will need to check continuity in the following conditions:
Switch Off: terminal 7 - terminal 10
Switch On: terminal 7 - terminal 8 and 4 - 5 - 6 - 9
If these do not match, switch is bad.
Hope this helps.
Glen
Thanks for the direction, LandTank please educate me on how,is the trailler hitch affecting the turn signal and flasher if they are are not working? please remember I am a new to this.
Brindleboxer
Thanks for the direction also, I am only experiencing no turn signal and no hazzard. I assume all the relays are in the dash, but i have a question on this, are the relay switch related in that if one is out, the other will also be affected?
the harness has a box that gets integrated into the rear tail lights for directionals, stop and running lights. The connector that is outside gets corroded and contaminated and shorts it out so the rest of the system is effected.
So take out the PS rear panel and look for a small black box that is plugged into the harness and remove it. There is also a wire that runs along the tail gate sill that gets plugged into the other side which can get grounded.
