No start
Sandy Utah area
I had some electrical troubles recently, an injector short caused my AM2 FL to blow a couple of times before I was forced to replace it with an inline blade style fuse (7.5 amp for safety). It worked and it got me home from the Maze safely but this morning I went out to my truck and I couldn't start it. I had power but it acted like a dead battery. Just a click and nothing else. Its a new AGM battery that measured 12.2 volts across the terminals. I tried to jump it with an anti-gravity and my old battery to no avail. The fuse I replaced the AM2 FL with wasn't blown and the AM1 and MAIN looked intact too. The Ingition fuse was good as were all the fuses in the main underhood bus. Not sure where else to look? it was acting a lot like I was trying to start it out of park, but its in park. Any new places to look?
When you turn the key to the on position do you have the check engine light?
Have someone else that can turn the key? If so have them turn the key from off to on while you listen by the driver front tire. If you here an audible mechanical noise coming from the starter then it's likely just contacts. If not then it might be other issue. If you hear the audible mechanical noise that coincides with key turn, then crawl underneath with a hammer and lightly tap the starter body while someone turns the key. If it's contacts this should get you going.
Nope. Just clicks, My trusted LC source - FJ80Toyman - think its my starter contacts, and my other electrical troubles are just coincidence.
That is what it sounds like to me... Had the same thing happen a few years ago. Try tapping the starter with something while having someone try to start it.
I can hear the click from the drivers seat, when turning it, I will use the clarkson tool when I get home then order a rebuilt kit to solve.
