NO spark!!
I have a 1971 FJ-40 with I6, all stock toy! I am here at Ft Rucker Alabama for a few more months.
Hello all, After 2 years of sitting I primed the engine cleaned off the spark plugs and turned it over..
Nothing...
Went to the auto parts stoire to have coil tested, it was bad. I replaced the coil and reinstalled it..
Still no luck!!!! Not sparking to the block at all, could it be bad distibutor?? Or points System?
Give me alll the advice you have
Thanks
Tom:doh:
Pop you dizzy cap, clean and adjust the points. Check all the wiring connections, clean any corrosion from them. Check the rotor button for corrossion. Replace all the above if they look burnt. Check ALL fuses.
Thanks
Thanks for all the suggestions and info I have like 3 months to get my cruiser from a complete restoration to full on driving so I sure do appreciate it lots.
Thanks Tom:cheers:
if you still have no luck, check the condenser, if that goes nothing works either...
if i were trying to get a rig to come to life after a few years i would replace cap,rotar,filters,oil ect..do a full tune up and it might make a difference. check your points and ajust or rip 'em out and go for a electronic ignition like pentronix or a whole new dist but its more $$$
Start simple and work up:
Disconnect the distributor wire from the - side of the coil. Turn the key on and momentarily ground the - side of the coil. If you get a big fat spark, everything upstream of the distributor all the way to the battery is good. If not, you aren't getting power to the coil.
