No idea
The Ghetto
What vehicle is this axle off of? I was getting my brakes checked out when I needed new rear drums. The brakes guy was like ???....smaller and older truck maybe? I know some you all have said it's out of a mini truck but which one? I'm asking because I need some new shoes....and maybe a couple other things. Also, as you can see that the diff is leaking too. I literally parked 5 mintues before it dripped two drops ont he pavement. Pic below.
mdjohnsen said:
I literally parked 5 mintues before it dripped two drops on the pavement. .
hell, that's nothing. you should see what my t-case does. :)
measure the distance from backing plate to plate. The guys at the toyota truck forum will be helpful here. It does look like a mini truck rear, which I think were mostly the same from 79-95, except for gear ratios, and a wider one for v6 trucks. This is just a guess, those guys would know.
That is a minitruck rear..
does nto really matter which width. All the seals and such are basically the same.
Refrence your parts to a 84 4wd mini. 4 cylinder
Yes, Toyota Minitruck.
mdjohnsen said:
Yeah, We refer to Toyota pickups before the introduction of the Tacoma as "minitrucks". Not sure where it came from, the correct foreign market name is "Hilux" but we don't seem to use that term here.
A parts store...
Again, what is the WMS on it?
You have been asked this multiple times and I have not seen an answer.
Getting the width of your rear axle will do wonders in figureing out what it actually is.
Like I said, measure the inner rim to inner rim, then add 7"
Go do that now..
