No Front Drive Shaft
Does it do any harm driving around without the front drive shaft on a vehicle that does not have the part time 4wd modification?
You will need to lock the center differential or the viscous coupler in the transfer case can overheat and seize. Once the center diff is locked, you can drive without issue with 1 driveshaft. However the handling of the vehicle will be different.
My understanding is that with the CD locked, it is functionally identical to any part time 4WD Toyota truck.
I assume you can lock the centre diff when in high, or do you need to do the CDL mod?
As per @jonheld, drive around town not really noticeable the front prop is missing, put your foot down hard on the twisty bits and you may get an unpleasant surprise.
Regards
Dave
No "mod" needed, shift low range to lock the center diff, remove the Diff fuse, shift high range and drive. When you want it unlocked, simply replace the fuse.
Realize though, that the guts in the front axle will still turn and you will NOT get better gas mileage because of this.
So, if the reason you're removing the front shaft is because there is a problem inside the front diff, then there is no point.
If you're doing it because you have bad U-Joints or bad vibes due to the DS angles, then yes.
The only way to stop the front guts from turning is to remove the drive flanges and / or convert to part time lockout hubs.
Thanks for that, I was unsure if the mod was needed or not to keep the diff locked when moving back to high.
Regards
Dave
No harm but it drives completely different. After you replace the front drive shaft you can do the same with the rear driveshaft when you want to swap out the u joints. With just the front it drives like a really slow, cumbersome corolla!
Yeah, torque steer and front wheel skids are interesting to experience in an LC :steer:
Haha I can tell you from first hand experience that you can drive just fine without a front drive shaft. In fact, if you were a terrible human, you could remove it, along with the front diff, and sell it to someone!
If there was ever a guy that deserved a bag of burning poop on his doorstep, it was the guy that sold you your truck.
That all depends. If he did the work himself, sure. If they had a shop perform it, not his fault.
Or he may of sold his pile of crap because he knew HIS shop screwed HIM?
A Toyota person willingly taking their stuff to a chevy/Ford place doesn't know the difference
Don't mean to laugh at your pain but this was pretty funny!
Ah the debate repeats and so does this sentence:
A 4wd will always have better road holding than a rwd.
You cannot overturn the laws of physics!
Regards
Dave
