No CEL
Byhalia, MS
I have been checking through the emergency trouble shooting and no cel guides with no success.
My 94, FJ80 ran fine all but low idle but also was runnig with the cel on. This started when i had aftermarket cat back exhaust done so i didnt think much of it.
I pulled the throttle body to clean it due to the oil/carbon buildup as well as the intakes...in doing this i had to unplug the wire harness and tie it back until i reassembled.
When firing back up i didnt seat an injector all the way so i had some fuel leaking. Re-seated the injectors with new o rigs and now , no spark, no cel...
I wasnt sure if having a fuel leak would shut down a relay that i would have to address but this still leaves the no CEL...
I have checked the EFI relay, it clicks and has voltage, the efi fuse, the pin 8 in the Diag box. The phillips screw for 12v...the wire harness looks to be solid. Not corroded.
Any takers????
As the question was previously raised, how many threads are you going to start related to this problem? Each time you have failed to disclose key factors that may have caused the problem. This thread we now learn you had a catback exhaust installed. Last night you posted that you power washed the engine bay in another thread. You are making it impossible for people to provide assistance because of multiple posts, not providing answers to the questions asked or following the testing procedures suggested. Stick with one post.
Sorry, i am new to thread posting and the like. I did not pressure wash anything. Jist had the valve cover powder coated as well as intake.
Does this mean i am to disregard this thread?
See my thread, tons of info their to maybe help you.
You are referring to my thread not this one...
Well my next step is to just replace the fusable links and efi relay and then check ecu for power.
Hopefully i get somewhere otherwise im having it towed to the shop.
Ok, new fuseable link, efi relay and lots of sounds from different systems when the key is "on".
Still no CEL.
Power 12v, at the test point at firewall.
Any advise on testing power to ecu?
Ok, i just got my Vain Air Flow meter back from being rebuilt and that what the shop suggested was wrong. I can only pray when they install it!!
Yes, eveything in place and new fusable links as well as efi relay. Sure hope the old cel pops on when this rebuilt VAF is connected.
Well i checked for 12v at the power port on passenger side in engine compartment and in efi fuse box. Shop said power was good to ecu.
If anyone is still watching this thread, the culpret was the Vain Air Flow sensor...
There is a guy with a posting on EBAY , "pullnparts4ya" that rebuilds MAF and VAF sensors...fyi..
I believe your 94 (pre OBD2) has an air flow meter (AFM) not a VAF. In any case, glad you got it sorted.
