No CDL dash light
Godwin
Resident Herpetologist
Alabama
About a month ago I got into a situation and discovered that the CDL was not locking, at which time I also noticed that the CDL dash light was not coming on. Yesterday I pulled the CDL switch and tested it and it appears to be no longer functional; I saw no change in continuity no matter the position of the switch.
Question is will the dash light not work if the CDL switch is bad? I've read through many of the CDL threads and if the answer in any of these I've missed it.
Push your button go undernieth your rig, take off the plug on the front of the transfer case (11 O'clock) and jump the two terminals. Easy with a paperclip and a partner in the rig. If your CDL light comes on your switch is bad. 5 minute replace job. Sadly Toyota charges 85 bucks for it.
Finally found the time to check this out. Jumpered the terminal and the dash light works as do the CDL and diff locks (well, except for the rear but that's with the actuator). Time for a new switch.
Is the switch referred to above the part that's screwed into the top of the transfer case at 11 o'clock?
The switch is on top of the transfer case forward of the actuator and toward the passenger side. I've only seen it while lying under the Cruiser but the 11 o'clock position sounds about right.
I took a stab at cleaning the switch today. After pulling it I shot a bunch of CRC electrical contact cleaner in the switch and worked it in and out. I went through this process about 6-8 times then reinstalled the switch. This did no good. Then after reading on George's site (CDL Sensor/Switch) about using voltage to clean the switch and that it may be possible to use a 9v battery to accomplish the cleaning that's what I tried next. I rigged up a 9v battery to the switch plug and worked the ball end in and out a number of times. A check with a multimeter revealed apparent success but upon reinstalling the switch the CDL still refuses to engage nor is the dash light coming on. I followed up by jumpering the plug on the harness and the light does indeed work and when lit the CDL will engage. I think I will follow up with another round of 9v cleaning and maybe also give it a whack or two with a hammer. At this point I can't see that I have much to lose.
Pulled the switch out one more time and tapped each of the flats of the hex with a small hammer. Following that I hooked up a 9v battery to the switch and worked the plunger in and out a number of times. Reinstalled the switch, dropped the t-case into low range, and now have an operational CDL.
Jim,
Glad to hear it's working again for you. Do you think it was a case of the switch hanging up due to lack of use?
After we got our 80 last August, I ordered a CDL dash switch, installed it, and did the 7-pin mod. When trying it out, it seemed to hang up at first, but working it back and forth got it to working reliably. The truck was a previous one-owner and I suspect it rarely, if ever, saw low-range, and thus CDL, being engaged.
As I write this, I'm reminded that I'm probably due to exercise the CDL.
Godwin; Is there room get the little red spray hose of the CRC contact cleaner past the ball to really spray the crap out of the switch?
Has anyone ever torn one of these switches apart to see what actually goes wrong inside? Is it corrosion building up on the internal contacts or lubricant getting past the little ball?? Seems like being all sealed nothing should happen to them that would be fixed by cleaning and banging, but it does. Anyone got a hacksaw blade?? Curious how the 9V battery thing would help, any ideas??
I think that there was a light degree of corrosion within the switch that caused it to initially quit responding. I had been periodically engaging low range to check its operation and then the one time it was needed to work it failed. With the battery wired to the terminals and working the plunger in and out I could feel what seemed to be a roughness that smoothed out. From this I'm assuming that there was some corrosion that was loosened with the hammer blows then somehow further cleaned with the electrical current, at least that's my WAG.
I'm not sure the CRC contact cleaner did any good. With the switch out I inverted the thing and sprayed enough fluid to fill any spaces and saturate the insides of the switch. I got the idea for using the 9v from the link I posted in post #6.
Could you describe what you did, I'm confused. Tell me if I got it right; you removed the switch by unscrewing it from the transfer case, then with the switch in your hand you worked the ball on the bottom in and out while a 9V battery was attached to the terminals of the switch??
This makes me wonder if the corrosion inside the actuator/switch is caused by the heat of operation leading to moisture being alternately stirred up and then condensing in the air inside the transfer case. Obviously more of an issue for folks in places with high humidity and less so in environments that are dry.
That's right. I used two pieces of thick wire, I think it was 10 ga and used a strip of electrical tape to hold one end of the wires to the battery terminals. The other ends of the wires were held in contact with the terminals of the switch. These terminals are down in a collar and by using the heavier wire I was able to jam the wire in the cavity and have it remain in contact with the terminals. At this point I simply worked the plunger in and out.
