Anybody know the Allen head size and torque spec for this plug on the upper oil pan?
I tried a 10mm and it is a good bit biggerI think it is a 10mm Allen key for that one
Copy that thank you!Then it's a 12 or 14. I haven't looked at that one in quite a while. I seriously doubt it's 17–mm, but those are your choices.
I didn’t know till I went looking!Am I the only guy here who didn't know that existed until just now? Did Toyota decide to allow a way for owners to change the oil when the rig is at a steep incline, hence the No.1 Oil Pan Drain Trick?![]()
I’m searching for the cause of a persistent engine tick. I just wanted to go around and make sure everything is torqued to specFWIW- That plug is 99.9% likely to NOT be the source of any leak. It's more likely to be the oil pump o-ring, or the o-ring between the timing cover and the block. Leave it alone!
