Nitrous (NOS) in a 3F?
From my experience it helps to manually keep those RPMs up as high as your ass cheeks with let you. ie: Dont be afraid to shift down to 3rd or 2nd WAYYYY early. I bomb mine at 3500 all day up the mountain to keep speed.
You should try shifting into 3rd @~70mph which puts me at about 3400rpms and into 2nd @~45-50mph. (my ratios and speed/odometer are VERY close to stock) Depending on the grade and wind resistance this can help alot. At the least you will be a few miles closer to the pass before you hit 15-20mph:hhmm:
Since NO one else will....I will
I'm running 31's till there gone.... so what would be my top speed with 4:88's??????????? 35mph????? WTH!
mph x final drive x O.D / (divided by) Tire dia x 336
Alright, now some things you need to remember here is 1: you cant put a gear in the calculator you think you running, it'll be inaccurate or wrong. Like I said. I use, .10 per 1" so because you are running a theoretical gear (not the true 4:11) adjust this to work in the equation. And 2: It's an equation for an SAE, its not for a metric tire so heres the formula for that:
tread width/ 25 x aspect : x 2 + wheel dia.
265/70x16
265/ 25 = 10.6 (which incidentally is the tread width in ")
10.6 x 70% = 7.42
7.42 x 2 =14.84
14.84 + 16 = 31.84 (which incidentally is the tires height in ")
see?
Now, "what would be my top speed with 4:88's??????????? 35mph?????"
Is that a trick question? :D
I'm assuming you mean rpm at 35mph with 4:88's and 33's, If I am correct here goes.
33 x 4:88 x .71 = 114.33 / 33 = 3.46 x 336 = 1,164rpm at 35 mph
And since the OD is most likely not on:
33 x 4:88 = 161.04 / 33 = 4.88 x 336 = 1,639rpm at 35 mph
And since it wont be in either one of those gears (OD or 1:1< 3rd) and I don't have the proper gear ratio's I cannot tell you the answer to that
Well snap,....ask and yee shall,......but I aint doing it!, uh uhh
A440F
Produced January, 1990 through July, 1992 on U.S. spec FJ80s
1st gear: 2.950 to 1
2nd gear: 1.530 to 1
3rd gear: 1.00 to 1
overdrive: .717 to 1
I've got a headache now THX!
Now take your factory settings and compare them to your theoretical gear, and look at the difference in RPM's
piece out
