NIMH batteries
Chicago
I just started using the rechargeable NiMH batteries in my Garmin handheld and I'm not getting the life out of them I thought I would. With the same settings for backlight etc. they seem to drain faster than regular alkalines. They are new batteries and a new charger, should I be expecting more out of them than the alkalines? I do have the GPS set to use them and not the alkalines.
It often takes a few discharge/charge cycles for new nimh cells to achieve full capacity. What mah rating are your nimhs? Does you garmin use AA or AAA?
For relatively low discharge draw like a modern GPS, alkalines can give similar or better performance than nimh cells.
cheers,
george.
With NiMH batteries, they start out at 1.2 volts instead of 1.5 volts. If the item you are powering is not all that voltage sensitive, you can get a lot out of them. However, the charge does not have a very long shelf life. And if they drop just a little, many items will not work. You may want to look for NiMH batteries that are specifically marketed as having a longer shelf life. I've used them and they really do hold a charge longer.
I have Lenmar and Sunpacks. After using them more I'm happy with them. The gauge is highly inaccurate. I got about 8 continous hours out of the lenmars with full backlight on all the time. The sunpacks were less by a couple of hours, but it was the first charge on those.
