NGK Spark Plugwires.
CouleeDamWA, BoiseID
Im looking at a set of NGK plugwires that are going to cost me about 70 bucks. I have enjoyed using NGK for years. But I have only used their sparkplugs. Is it worth the money to buy a set of 70 wires or just get a set of premium wires for less money?
I used a set ONCE on my fj80, the plug wires melted to the plugs.............NEVER again.................always OEM wires
Don't buy the non-oem plug wires SOR sells. I bought them for some reason and broke 5 out of 6 when I tried to pull them out of the cap. I run the Napa spark plug wire set - Napa part # 700126 7mm (blue in color if that bothers you). This set is for the earlier F style engines that have the coil mounted to the block. If your coil is on the fender you need a different part number.
I'm running FJ60 wires on my 74
they're 8mm and have nice boots. The coil wire is long enough to reach the fender.
A great option IMO
a few things I like about the OEM plug wires(besides they last for a long time)
each wire is # for where it goes, if you use a OEM cap it is also #
each wire is the correct length
each wire is dated as to when it was made........so you will now years down the road how old they are.
I have NEVER had a problem with the OEM wires coming apart or melting
the original plug wires on our 90 fj62 still were within spec even 15 years and 250K latter.....find me another wire that will do that?
and the price on OEM wires is not much more(around $30-40 per set) than aftermarket crap........
