NGK Glow Plugs
Myrtle Beach, SC
Anybody have a source for NGK Glow plugs #7493? I need 10.5v. I have an Australian source, but need them sooner, so am looking for Domestic. Checked my local Advance, Auto Zone, and Napa. They were all confused. If you have a source locally near you, please give me their # so I can call and get some. Thanks.
Hello,
I logged onto the NAPA website for Canada, found a store in British Columbia who shipped them that day. I think I paid about 8-9 bucks each. I later ordered a water pump from the same store, no drama whatsoever! You will not find these in the US, I spent 2 days on the internet and on the phone, trying to find a US source, nothing. Called Canada and 20 minutes later the plugs and later the water pump were in the mail.
Hola
eric
Glow plugs!
Hey Otterav, I need glow plugs for my '85 3b, but I'm not having any luck on the NAPA Canada site.
Do you still have the contact info for that store in BC?
I talked to NGK USA and was told by customer service that if I found someone who had them it would be new old stock, and that they would not be imported by the company. FWIW I got 2 of the last new old stock plugs from a company in LA. You gotta talk to a human, in the NAPA store, once you do it is so simple its krazy!
eric
So for the 24v 3B-Canadian BJ, what is the correct glow plug voltage. Some posts say 14v some say 20.5v,etc. The above post that links to NGK's webpage show they(Y-147T) are available for $9.00 each. But it doesn't indicate what the voltage is.
20.5V for 24V system. I found this out the hard way after I ran my 3B in the BJ40 for a while with the plugs that came with it and the end melted off one plug and bounced around inside the cylinder for a little while until I got the head off. Fortunately no significant damage. When I ordered the right plugs I checked and they were 20.5V
Dan @ 4 wheel auto says the 10.5 volt glow plugs are not the right ones for an '84 BJ 60. he says for the 84 superglow system that the 6 volt is what we need. Nominal voltage has to right. and the ones that NAPA sold me (NAPA part number 7493) were 10.5 v. Sounds like NAPA is going to take them back even though they have been installed.
I use the 10.5 volt plugs with a momentary pushbutton/relay setup. im not sure if the 6 volt plugs will work with the superglow, connect a voltmeter for when you cycle the glow plugs in the morning and see if you get 12 volts. If you do i have a feeling these plugs wont last too long.
I believe there is a parts list for glow plugs in the faq section as well.
Why does it have to be NGK? HKT,Bosch will all do the same job.
they just happen to be easier to get a hold of.
Because Canada got the diesels, and the states didnt, and most all of our automotive parts and supplies are based on and come from there market, it is much harder to get replacement parts for most of the toyota diesels as the states never bothered to bring in parts for vehicles they didnt have.
Fair enough. Do the dealers stock glow plugs for 60 and 70 series sold in the 80s?
Cody, What you say about the 10.5 v makes sense w/ your manual glow set up. W/ the 10.5 V I have to cycle my timer system about 12 times then it will start w/ a huge cloud of smoke. Dan @ 4 wheel confirmed this saying that the "nominal voltage had to be right" for the system. And if you control the time then they could (sounds like the do) work fine. Last night I put the old ones back in(6 V ND 067100-1460) and it started better this morning. I'm hoping the new ones on their way from 4 wheel will make it start right up like it used to.
Joe
doubt it, i know i got glow plugs from a dealership in B.C. a long time ago but they were 6 volt plugs and lasted about 3 days, plus they were like $35 a piece. Napa NGK plugs were like $17 a couple years back.
We really cant get many diesel parts over here even maintenance parts are slim picking from most toyota dealerships. A lot of stuff isnt stocked because the toyota's are few in comparison and perhaps arent in for service as much as the domestic vehicles. ;)
To be honest i went to a dealership about 3 years ago for a part, i have much better luck and smaller bills with NAPA CDAN or IHMUD for most of what i need.
CODE621, you do need the right voltage plug for the job, if the glow plug is rated for 12 and the system is built for 6 then you get half the wattage. As for the other way around you get plugs that work good but only once or twice.
