Newcomer w/ timming & dizzy questions
Tacoma,WA
Just purchased a 75 fj40 and have a few questions, the timming mark is clearly marked with a white stripe from the previous owner, but thats about it. No timming degrees, with the light on it's about 2" ontop the marker, when I try to move the dizzy, the vacuum retard( I think it's retard) hits the oil filter. Could the dizzy be off by one spline? Could the degree marks be painted over? Also is there a thread for decoding vin numbers on this site?, there's a month stamped next to the year, either jun or july, I can't tell. My vin is fj40201672.
There is a link in the FAQ if you get it out of allignment on how to set it right. It works better if you have a timing light with advance. The center mark is already 7 deg advance, so I set my timing light to 6 deg to get 13 deg advance for my HEI dizzy.
Make sure the dizzy is eated and you have oil pressure as soon as you turn the key.
There is a BB that is factory spec 7 deg BTDC. PO may have marked this with a stripe; confusing. There is a hashmark or strip on the flywheel also that is TDC. If your bell is on the oil filter side, it is prolly a vac advance, which is good. Get a good advance timing light; suck on the hose going to the dist to see if it advances or retards to tell for sure. Get an under the hood hand starter at Autozone also; put in neutral and bump the engine until you see the marks in the window clearly to determine what is what and what has been painted over. Can also remove the #1 plug, use a LED flexible light to look in hole, bump the engine until you see the top of the piston and "feel" a puff of air; this is compression stroke and TDC. If dizzy cap is removed, the rotor should now be pointing at the #1 plug POSITION ON THE DIZZY and the timing marks should be visible in the window. Use paint thinner to remove PO paint and mark the BB with silver or bright white and the hashmark with silver or bright white; touch up paint from Wal Mart works fine. Timing is fun for all; great opportunity to spend quality time with the wife. Chicks dig timing.
