Newbie needs Real Time Help
holy wow. sorry for not reloading and reading those previous post. thanks guys
little short on tools but goin as deep as possible
-JFZ80
Where did you guys find your 54 mm hub socket??? NAPA? calling around now
sears, autozone....both a no
either my tool box or NAPA will rent you one. For removing it, torque is not super critical so if you can rig something up, maybe big a$$ pliers or something.....
2 1/8" is the same as 54mm. I got mine at Sears. But I think Napa "might" have them too. If things are as loose as they sound, you won't need one to get the hub off unless your spindle has gotten trashed during this ordeal. You will need the hub socket to button everything back up.
You need the FSM too. You can download what you need (or the whole thing for that matter) for $10.
:beer:
Rookie2
The catch is he's in Raleigh, NC and i'm in HP, NC which is about 1.5 hours away. I have EVERYTHING he needs tool wise for a knuckle job, FSM and experience, but no way of getting it to him right now. Hopefully he can get it apart and see what he needs to order, then we can get tools together and go down and rebuild.
Well, sounds like you guys are buddies. If you can fax him the exploded diagram and the removal procedure, that would help him get it torn down enough to see what parts he needs to get ordered. Sounds like he needs to do a full front axle job.
Wow! good thing we/u caught this. There are horror stories on the forum of what happens at 70mph when things break in the wheel bearing area.
Paying attention to wheel noises like this is always a good idea. :cheers:
wheel noises
Since we are on the subject of wheel noises I have one I could use some thoughts on. High-pitched metal on metal kind of sound that only kicks in when moving and only after a while of driving (30 minutes or so). Brake pads are at 1/2 and rotors are new with no grooves or chunks missing. There is little or no play at 6 and 12 o'clock and the same at 3 and 9. When applying the brakes the noise does not immediatly go away, only when I slow down to under say 20 mph.
Any thoughts?
Any thoughts?
Make a new thread so as not to confuse the diagnosis on this one?
-JFZ80
54mm Bluepoint from my friendly neighborhood Snap On dealer.
In a pinch, since you have play in the wheel anyway, it probably isn't tight to begin with. Bend back the locking tabs (there are sheet metal tabs on the edges of that nut behind the grease). The nut will likely spin off by hand. If not, a flat drift on the top left corner of the nut can usually move it just enough so it will spin off.
Got a digital camera? It would help to show these guys what you're looking at.
SSBOB,
You described to a T what I am hearing on my 93. Been listening and figuring for a week. I think it's one of the wear indicators dragging on the disc even though I *thought* I just bent them back out of the way at my tire rotation last month. Same deal - it goes quiet around 20 just when the wind noise drops to where I might be able to figure it out. Can you get someone to drive it along a building with you in the rear seat so you can figure out which side and then which wheel? Mine's the right side, and I'm going to have my wifey drive so I can figure out front or back.
DougM
The winner is........Worn our wheel bearings and inner seal.
Thank you everyone who help me out on this one.
I have a local mechanic that I have found to be trustworthy over the years. He quoted me $250 to replace wheel bearings and inner and outer seals. This didn't seem too outrageous. He was going to make sure the PS side was tightened down properly as well. Anyone have an opinion?
I know the motto of this board is that the "Truth is in the rocks", but I would have to say that its "The Truth thats inside (this forum) rocks".
You guys are great, thanks for all the advice.
Here is some advice that I got from my mechanic (Robbie).
Use only Toyota inner seals, no after market crap.
Use only USA or Japan bearings, not made in Mexico stuff.
Good luck with it. Assuming he does it right, $250 sounds like a pretty good deal (that's including parts?).
