newbie needs brake help!!
Hey guys, awesome site. I just boght my first Fj-40, its a little rusty but runs great. Its a 74 Fj-40. Hers the problem, previous owner said he thought master cylinder is bad. If you pump her 2 or 3 times brakes work fine. It still has 4 wheel drums on it for now. Until I get the money to upgrade I just want to make her safe. I removed the drums and adjusted the brakes. Works about the same, no evidence of leaking wheel cylinders. So I guess I need a new master cylinder. The Previous owner said he thought the master cylinder was off a later model toyota truck, but he did not know what kind. It has a brake booster and two seperate reservoir caps. Is there any way to know what master cylinder i need when I go to the parts store? Thanks in advance for all the help.
Brad
Get a master cylinder rebuild kit from SOR or your local parts store. They will need to order it but it shouldn't take more than a couple of days. You'll need to buy a snap-ring plyers, i.e. pointed, reverse action tool from sears or wherever, very cheap, to get the retaining ring out of the master, then replace the rubber seals in there. Sounds a lot like fluid is leaking around them. One caveat, when you bolt the master back on, and are refilling it, only depess the pedal a little at a time until it's full and properly bled of air. The rebuild kit is cheap and it's an easy job you can do at your kitchen table, given that you have a patient spouse/girlfrend/roommate.
Welcome.
A later model Toyota truck in the USA would not have two seperate reservoirs, but rather, a single unit devided into two sections.
What you are describing sounds like a Land Cruiser master cylinder, but if you could post up a picture of your set up, we could verify that for sure.
While getting and installing a master cylinder rebuild kit is an option, I prefer to install a new OEM component, as I have found them to last far longer than a rebuild unit, weather it is a reman unit or something done on the bench or dinner table at home.
Good luck!
-Steve
After they're pumped up, they work fine, or they fade from there? If they fade after getting pumped up, it's the master cylinder. If they hold, you need more adjustment.
There are lots of cylinders to adjust, and they all have to be pretty close to perfect for the master cylinder to function properly. It only has so much throw, and pushing eight cylinders each a bit extra will take an extra pump.
Even if you don't rebuild the MC, I'd get some snapring pliers and take it apart and clean it.
All that said, I bought a new one.
My master cylinder was going south on me this summer; lots of pedal travel and multiple pumps to get good pressure. I bought a rebuild kit but when I got it apart I found it to be pitted pretty bad. Got a new one from the dealer. Just warning you that it might not be rebuildable, but if the cylinders are all adjusted all the way out then that sounds like the only other place there might be a problem.
Brad
Brad,
I removed the front discs from my '74, and replaced them with '84 FJ-60 discs and knuckles, was a piece of cake. Now to the meat of the matter, I have the drums, backing plates cylinders, and the shoes, all of the above parts are servicable with no leaks. The icing on the cake the mastercylinder was working perfectly and would lock up 33"X12.50"s when the wheel cylinders were properly adjusted. If you want any of the above parts they are yours for the cost of the shipping or even less($0.00/free) if you come and take them away. P.M. if you are interested.
eric:cheers:
