Sporin
Site Addict
Spent about a month hinting for a decent $4k FJ40 and came up empty. Found this pig in Rhode Island and had a buddy go check it out. All seemed well so I went and got it yesterday.
Hotrod Covette V8, newer 4 speed Cruiser trans dan tcase. Disk barked front axle which was abig surprise.
$14k worth of receipts in a folder. A good solid starting point. I was told the front drum brakes were bad so was prepared for a heart stopping trip home, and I got it.
After a brief test drive at pickup we hit the road, fingers crossed. Stopped at the first gas station right before getting on 95 to see if I could do anything about the brakes, the Dside front was leaking badly. Surprise! It's got disks but that caliper is SHOT.
Notice that the front shock hits the steering arm, that will need to be addressed. Looks like the tie rods barely clear the wheels. Looks like the money I set aside for a disk brake swap will go towards the steering instead.
Top of the brakemaster and get gas. Something is hinky. I assume I've overfilled it and it's purging from a evap valve or something because it's pouring out the Pside. Dammit.
Hit the road, gas gauge says way full and everything is going fine. We pull off at Quincy to stop at my buddy's house and I nearly rear end him, NO brakes, luckily I make a quick turn into a side street and get the truck stopped. Really scary there. Guess I need to top of the brake fluid more then once every 90 minutes.
Decide to bag the stop in Quincy and get right back onto 95 and head towards home, it's safest out on the highway. Stop to get gas and after 18 gallons it overflows again, attendant not happy.
Only had to make one stop on the highway for an accident. Somewhere north of Boston I realize I can clamp a vice grip on the bad caliper side's soft line. Stop at the first NH rest stop and do that. YEAH!! It holds and now I still have s***ty brakes but at least the fluid stays in it. A bit of relief.
Now the gas gauge isn't working (the speedo and odo never did) so I stop in Concord for gas, get about 5 gallons in before it starts overflowing. I'm not convinced it's overflow but off I go. Stop again in Warner NH and get a gallon in before it starts dripping. I say screw it and hit the road.
Steering feel funny, not bad off center but quite hard farther to each side, even at speed. Need to look into that. Gear whine is there but not so bad that I think anything is wrong. Stop in White River Jct. to get some gas and get a few gallons in. Last leg home I'd swear there is extra clunking, almost like a bad trans mount or motor mount. Need to get into that.
Arrive home, dirty, sweaty and beat.
So I have a few things that need attention before it can hit the road. Besides going through it end to end and changing fluids, checking bolts, etc., I need to address the bad brake caliper obviously. Then I need to figure out what's the deal with the gas and preferably get the gas gauge and speedo working. There's the clunking. Then I need to address the steering. I also really need to rebuild the axle so I think I'll do brakes on both sides and start fresh with new seals and everything.
It needs a cleaning. I think I'll strip the interior out, clean it up, lay in some dynomat and put it back together. There are a few places on the outside that need to see a sanding disk and some primer, nothing major though.
All 4 doors need adjusting, I have a couple of cracked lights in the back looks like the Pside rear corner got pushed in at some point. Time for those slick FoxFax repro lights!
I need to put in some real headlights, these are dangerously dim.
More later, need to get some work done.
