Hey there!
Just purchased a 1990 LJ78 with the 2LTE. These forums have been tremendously helpful for figuring out if I wanted to buy this thing and what ownership may look like. So, thank you! My background is in Datsun stuff so it’s neat to see how builds take shape on the Toyota side of things.
So far the truck has been a treat to drive. I purchased it on Vancouver Island and I’m told it was first owned by a lady in Comox who had it serviced regularly in Ladysmith. I believe at Flying Pistons. I’ve called them to ask for some service records as I’m not yet sure what head it’s got on it. It’s at 308000 km so I’d assume the head has been done at some point.
Previous owner looked after it and didn’t put much mileage on. Came with some service records, new turbo, rebuilt rad and an EGR delete.
First on the docket:
- I’ve noticed the OD light flashing so I’m going to pull the ECU behind the glove box and see if the capacitors are in good shape. Maybe replace them with high quality digi key items.
- I read that this could maybe be caused by a speedometer sensor (Speedo is also reading 20km/h higher even with 32 series tires) would that be part number 83181-20040 ?
- oil change
- air filter change
- pyro sensor and gauge (on order)
- water temp guage
- rear sway bar link rs
Next on the docket
- water to air intercooler
- boost gauge and sensor
- manual boost controller
- tend to a little rust
- minor aesthetic tweaks
- front seat upholstery to match rears
Further regarding that flashing OD issue, it seems like it’s sometimes starting from a dead stop with OD engaged in first gear until switched off or shifted into L and truck drives totally normally. On the highway I noticed the OD pulsing on and off occasionally. Any tips with this?
Goals with this truck are to do some slow steady road trips and light wheeling. I’ve read to keep these things under 3k, maintain them well and keep them cool and hopefully they treat you nicely in return.
Thanks very much! Looking forward to more! If you recognize the truck lemme know
- oil change
- air filter change
- water temp guage
Next on the docket
