but I didn't put AT tires on.Someone please post pics! I am about to purchase a set of these 20" Enkei's from a Tundra and need to see how they fit without spacers on the LX450..
thanks!
The offset is 15. Do you think it will work?
I measured the back space of the rim to the drum and it 's about over 2" needed for a spacer... CRAP!!!!!!
Steve- 96 LX450
drums???? on a 96 lx, this is new to me or mistaken identity.
CJ80:
Alright so I am a noob and I didn't use the right terminology... I was typing fast to get a quick and 'valid' response from a forum member and not some BS.... So do you have any knowledgeable input that will help?
It looks like the 06 Tundra has a 106.mm hub and my 96 LX450 has 108mm, thus the rim not fitting... So I need to find out which size wheel spacers I need. If a 1.5 " works and the rim won't hit the hub, I'm fine, but I doubt the 1.5" will suffice and it looks like I need at least <2.5" space, which TG only offers 2 and 3" and no 2.5". Also the 3" will put the rims/tires about 2" past the flares, which I would not want..... So I am in a pickle with these Enkei's..
OK... I picked up the set mentioned above off a Tundra with the sport 20" rim Enkei package. The guy measured the diameter of the center bore and it said it was over 4-1/8"... So I measured my stock rim and it looked right around 4-1/8 to 4-1/4" (or right under)... Well I get home and try to mount the rear and it doesn't clear the hub .... almost but I need about an 1/8- 1/4" more room.... I measured the back space of the rim to where the base of the lugs (whatever you call that) and it 's about over 2" needed for a spacer... CRAP!!!!!!
So my only option is to buy 3" spacers or if they make 2.5" spacers.... Trail- Gear makes 3" but Slee only offers 1.5"
Anyone has any 3" spacer with nuts laying around that they want to sell??
email me biaggi@nc.rr.com since my PM's don't seem to be coming through.
Thanks in Advance!!!!
Steve- 96 LX450
CJ80:
