Wrenching on my Junk
After my bent front axle fiasco in Death Valley last November I have been wanting to replace my worn spindles. Maybe this is contributing to the truck's tendency to wander within the white lines on the long boring highway
ATEB said this is indicated by circular groves cut inside the thrust washer. Apparently if the spindle is worn it can will allow the inner bearing ring to move under high side loads even when properly torqued.
Well I ordered a new set from Akella (mud vendor) last Christmas ( i.e., from Santa) and it has been warm enough here to install them. I torque my wheel bearings to 43 ft-lbs and checked them will the spring gauge as per FSM, which got between 4-5 lbs bearing preload (FSM is 1-7 lbs,), without the caliper on.
I will see if this helps....
