New Rusty Birfs
North Front Range, CO
I am still waiting for a call from CV Unlimited about the broken Newfield.
Meanwhile, I found a pair of new unused but rusty OEM birfields.
Is there any problem with rusty new birfs?
Would they be good for a spare or even replacements for the Newfields?
Howdy! If it is surface rust on the outside of the body, then wipe or sand it down and run them. If it is only surface rust in the balls and cage, have some one bead blast them before using them. Sandblasting will remove too much surface metal. John
Kurt,
A rusty part that's precision ground should go for pretty cheap considering the time and effort to make it right. If they were new OEM, I'd say they're worth it if offered VERY cheap (like both for $100 or something) but if theyre aftermarket AND they're rusty they should be free. How the heck did new birfs get rusty?
DougM
I'd want a look at them first. Light rust, particularly on the outside - go for it. Heavy, pitting rust inside and on the balls and cage - forget it. Light rust inside ... maybe if they were cheap enough.
