New rig = New built
Fl
Well i am new to the forum, my name is Ender i am from Venezuela but i have been leaving in miami for several years now. Well lets get into what is important!!
1996 lx450
i have been owning this rig for the pass 8 month and this is whati have done to it.
instergram: globeoverland
Viper roofrack was next! i did a full sandblasting job and new black powder coat (original paint was in really bad shape)
full front and rear dif maintanence
- New bearings (all of them)
- New seals
- New gasket, spindle, dust shield
- New tie rods
- Nitro gears 456
- Rear Tjm Air Locker
- ARB front and rear dif breather (at engine bay)
- New Oil, Grease etc..
Welcome to the club. Looks like a clean 80 and you're off to a solid start. Looking forward to seeing those tires and rims installed. Where did you get those rims, I don't recall seeing this's before?
Thanks they are OEM toyota wheels they come on 4runner trail edition and fjcruiser
Engine (SURE I AM MISSING STUFF BUT THIS IS WHAT I REMEMBER)
- New oem starter
- New oem alternator
- New oem distributor
- New hoses ( entire engine )
- New silicon radiator hoses
- New oem belt
- New Gaskets oem (entire engine)
- New valve and valve springs oem
- New Spark plugs
- New spark plugs cable oem
- All pulleys oem
- Slee windshield relocator
- oem 2nd battery tray
- Brand new toyota Battery
- New Optima Yellowtop
- New throttle cable oem
- All fluids
- ARB breather ( transfer, gear box, front and rear dif)
- New oem intake hose (stupid expensive)
- oem All oil and fuel filters
- oem engine mounts
Before an during
Damn you ain't messing around! Are that the OME 5" competition kit? I notice you sit pretty level even with out the RTT on the roof. Looking great!
Thank you, yes that is the OME 5 inch competition (ironman caster plate, long brake lines, Custom doble steering OME shock, rear Sway Bar Brackets, front Sway Bar Drop, custom 1 inch gear box lowering spacer, front and rear adj panhard and front dc ) all this to make to make it work correctly
Do you have any vibration from your rear drive shaft? Any at all? I have a slee 4" with progressives in the rear and have a small vibration issue on deceleration that persists even after adjusting my pinion angle and rebuilding the shaft.
