New racer carb
Western Massachusetts
Hi all,
Can someone tell me the pipe thread size and what type of thread the male end is on the fuel inlet of my new racer65 carburetor. I tried a 3/8 npt at the napa and it didn't seem to be correct and I would think it might not be npt thread with it being a japanese carb. Also, the old weber I'm replacing has a metal fuel line from the pump over the valve cover and then transitions to 5/16 rubber fuel line to the carb. It's been like this since I had the engine rebuilt a few years ago and hasn't been a problem, I'm sure metal all the way would be the best, but do you think running it the same way is bad?
Unfortunately this probably won't be my last question on replacing this carb as I've never done it before so be gentle.
Hi all,
Sorry, I can't help you with the inlet thread size.
The metal fuel supply line that goes from the carb and then transitions to rubber line a few inches before the fuel pump came that way from the factory on later 2F motors, so should be fine. Also, I believe it's a barbed fitting on the fuel pump so I don't see how you could run a metal line all the way from the carb in this application.
Thanks for the response, I haven't looked at the fuel pump end I'll check out how that's connected. I need the thread size so I don't mess up the threads by using the wrong barbed connector.
@curtislow
I believe the standard connection at the carburetor is a 5/16" (8 mm) steel tube with a ferrule (olive in Toyota parlance) and compression nut. See the following picture from Racer's site:
Here is the illustration from the Toyota parts sheet:
1949005
Cityracer says to eliminate the return line, which is likely non-existent on your current setup.
Toyota part numbers:
Olive - Toyota (96395-71400) $4.11 list
Nut Union - Toyota (90402-13041) $6.09 list.
Some folks have used the U.S. 'olives' and maybe U.S. nuts, but I can't say they're the right ones.
The nut should thread onto the nipple easily, (without the tube or olive in place) since the threads aren't tapered. The installation concept is to put the nut on the tube, then the olive, then push the tube into the fitting, then tighten the nut to squeeze the olive against the tube to seal it. Don't over do it, since you're only holding up against a few psi in pressure.
Note that the OEM standard arrangement is to run the steel tube all the way from the pump outlet to the carburetor. A rubber fuel line routed near the exhaust manifold may not be the best arrangement.
@curtislow :
This OEM parts sheet shows the later 1977 fuel lines as well:
Thanks, I've done plenty of plumbing so it's basically the same. So maybe I should get a new piece of 5/16 fuel line and just redo the whole run from pump to carb., not to big a deal. Or should it be 8mm? I'll order a nut and ferrule ( olive ) from toyota tomorrow.
I see your from Western Mass, do you have luck with any toyota dealers around here for your fj40 parts? The people at Lia toyota didn't seem to interested in helping me here in Wilbraham.
I'll send a PM.
8 mm and 5/16" are the same.
5/16" = 0.3125 inch
8 mm = 0.315 inch
The difference, 0.0025, is less than the manufacturing tolerance for the tubing.
