You are probably right. I just have the magsafe mounts, no charger,Ah! Thanks!
I saw the bullet point holder but my googling never turned up the bulletpoint charger. I didn’t know they made a charger.
Darn. I now see that the Bulletpoint charger has a 20mm ball on it. Not a 20mm socket.Ah! Thanks!
So I will still need an intermediary between the Offroam mount and it.
Yes. I fwd their link to my attorney
I'm in also. GroupForward it to me - let’s make it a class action. There’s at least a dozen of us in the continental US
That's just great. It looks better than my 20mm to 1" adapter as it's flatter. Now I need 2 of those. DAGNABBIT.So I ended up buying this use between the offroam mount and my MagSafe charger:
It’s pretty great. And as minimalistic as I can find.
I haven’t off-roaded with the phone mounted, but it all feels very solid. I would recommend.
That situation is what caused me to go from magnetic to locking. The magnetic Peak Design mount worked well 99% of the time and was so easy, but if I ever hit anything big or washboard type ruts where the frequency was right, the phone would get flung off with force. Good thing Peak Design made a locking version that works with the same case. A little more work to disconnect, but not hard at all. It's not going anywhere though. You can get it in 1" or 20mm. You do need their case though, their stuff is pricey but high quality.Is there a consensus on if the Bulletpoint or Offroam magsafe mounts are strong enough to take a decent pothole, and does that require the phone case to be removed if maximum retention is the desired end state without a big multi-arm style mount.
I’ve used both offroam and peak design mounts off road, in the desert, at speed, in the whoops, etc and never had the phone come off. I do use a PD case which has crazy strong magnets. But yea I usually have OnX running on my phone and it works like a charm.Is there a consensus on if the Bulletpoint or Offroam magsafe mounts are strong enough to take a decent pothole, and does that require the phone case to be removed if maximum retention is the desired end state without a big multi-arm style mount.
