New or Used Muffler
North Front Range, CO
A used OEM muffle is $100. My muffler with 437,000 mi is getting close to being replaced, rock damage and cracks.
Is there a muffler as quiet as the OEM muffler for about the same cost as a used muffler? I do not want to hear any more exhaust noise than what the OEM offers.
My Walker muffler is pretty quiet. Just measure the space and get the offset version. Sorry I don't have the part number but their website is pretty easy to get around. I also have the Magnaflow Y pipe and no resonator so that ups to sound a bit.
used muffler is 100 bucks?!?! i am sitting on a gold mine then! seriously, you cant find someone nearby doing a part out to sell you one cheaper? my old LX had an aftermarket muffler and it was terrible. the 1FZ has just a terrible sound. it needs to be quiet.
No muffler is going to be as quiet as the OEM muffler, it's pure physics. I run a Bosal system with an additional tail pipe muffler and it's as quiet as OEM. I can't for the life of me can't recall the name of the tailpipe muffler. It's SS and oval shaped. Was it Meridian, maybe?
  • Like
Reactions: KTP
Take the money you save by buying a loud muffler and upgrade your stereo... problem solved.
  • Like
Reactions: KTP
If I didn't take mine up and over the frame rail I would have gone Magnaflow Y pipe and second cat then OEM the rest of the way. If I recall the OEM y pipe and second cat is $1200 and ~$600 for OEM the rest of the way back. And you'd be able to bolt it up yourself.
FWIW, when I bought my 95, the PO had removed the rear Cat, installed some hacked up muffler and some cheesy tailpipe setup. It was obnoxiously loud.
Due to the way the pipe was hacked from the front cat, I ended up buying a magnaflow OEM style Y pipe with front cat, a rear cat, new O2 Sensors, a bosal muffler and bosal tailpipe. I found the system livable. Certainly not as quiet as an OEM setup, but it was ok. I really like alia's setup with the additional rear muffler/resonator setup.
Just cut the rear end - no need on that part, I broke it several times backing up into pail of dirt and then modified it
