New Motor?
So $2600 for a short block, maybe get a rebuilt head from Torfab or Slee or ??
As far as Blackstone how many miles should I have from last change?
Can I just grab a few ounces and send it off now? Not change the oil just yet?
Dealing with Blackstone is like having your own personal laboratory, they are great.
Yes, you can send them a sample whenever you like once you have there sample kit, which is free.
Warm up the engine thoroughly, shut her off and take your sample immediately. If you plan to re-install the plug once the sample is taken it may get a bit messy. Don't get burned.
Blackstone can tell you everything you need to know. Even though your oil has few miles, if you have an issue, it will be detected because they know what your oil status should be for a given amount of use.
Maybe I did not read this thread carefully enough but I don't remember reading where you have a actual and real engine problem that dictates an engine replacement right now. I think that your mind will be at ease once you find out what your oil pressure actually is per the FSM procedure. Don't try to fix what isn't broken.
I don't understand what is going on. Why all the flipping panic? Drive it. Pull an oil sample. Send it. Keep driving. Get results. Keep driving. Make educated decision.
The oil pressure gauges on 80 series are about as reliable as a screen door in a submarine.
For sh!ts and giggles you've checked to make sure you have approx 8 qts in it, right?
This might be stupid..... I have been wrenching for a long time, what do vacum leaks have to do with oil pressure. On a more educated note, your oil pump could be wore out, and unlike many engines you can get to it easily to fix. K.I.S.S.
I would not call any of this 'flipping panic' - more like some people providing advise (THANKS) talking about options, things to test and what might be really going on.
I now know I can't really trust the gauge, I know that Blackstone offers more than just a sheet with numbers, I have had a few PMs with offers for blocks and used engines (huge help BTW), I understand why all the fuss over LS swaps (cheap), and support in what might be the end days for an old 4.5 (kidding)
I have no idea on vacumm leaks and oil pressure. I do know this from first hand experience. Synthetic oil is a waste of money. These are " truck " engines and always have been since 1957. I tried synthetic just for the heck of it - major fail. I am going back to Rotellla 10-40 when my supply of synthetic runs dry.
Truck engines are loose and made that way. They use oil. Anyone who claims to have a Landcruiser that doesn't burn or leak oil in some fashion is toking weed. Go check your dip-stick. Don't rely on idiot lights. Have a nice day all.
~~ On a more educated note, your oil pump could be wore out, and unlike many engines you can get to it easily to fix. K.I.S.S.
I did pull the cover to replace the seal a while back because it was leaking bad and it looked all ok but then again I was not looking for internal issues.
Pressure tester hooked up. It is a $30 one from Amazon but seems pretty good. Not sure how accurate the gauge is but here is what I have gathered:
First pic is cold start at about 40deg
Second it after 4 mins idling
Third 8 mins later idling
4th is about 2000 RPM no load
At no point did it get over 28-30 psi. Hose on tester is too short to do any driving test.
So at idle the pressure is slightly above spec and at 2000 rpm it is slightly under the minimum spec given for 3000 rpm. Allowing for a bit of gauge error (Amazon factor) your pump is OK just. I would be happy to continue to use the engine but perhaps do an oil sample just before each oil change period and get the report before deciding when to change the oil or wait a bit. After all that is what fleet operators do.
Whatever made your oil all silvery is either going to continue to deteriorate or has failed completely.
And it is not making any bad noises at the moment so you have a bit of time.
I will say that as I held the RPMs between 2-3k there was a bit more noise than normal...not sure if that was a no load piston slap or just straight up an engine headed for doom.
That is a bit lower than one I tested recently. With 15w40 oil mine read 60 psi immediately after start up and settled down to 22psi at warm idle of about 800. This engine was rebuilt about 18k ago tough.
Blackstone can tell you a lot and have save many people from spending more than necessary on repairs.
